whats the best soldering iron
rt4x4
Copper - Posts: 107
Posted: November 21, 2007 at 10:56 PM / IP Logged
what kind and what type of soldering iron does everyone use?
Twelvoltz
Platinum - Posts: 2,384
Posted: November 21, 2007 at 11:32 PM / IP Logged
My tool of choice: Click
I will admit, I burn through tips every couple of months but other than that I have no complaints.
godd dan it
Copper - Posts: 447
Posted: November 22, 2007 at 12:15 AM / IP Logged
I got the same one. Works without any problems. Weller is another good brand.
rt4x4
Copper - Posts: 107
Posted: November 22, 2007 at 8:16 AM / IP Logged
what about one of the weller guns or do they get to hot or does that matter and what about the weller cold heat pro?
enice
Silver - Posts: 857
Posted: November 22, 2007 at 8:54 AM / IP Logged
I was actually looking at a weller version and looks exactly the same!!!!!! If it didnt have the weller logo I would swear its the same.  My question is what kind of butane do you guys use because the ones i've had seems to go bad after a while like it gets clogged up and does not ignite anymore.  Its expensive to use the butane that snapon sells but if thats the one that works then I would need to order  a case.  Also I actually use a weller corder iron.   My snapon drop light has a power jack that i connnect the iron to and works great.   Funny that its a weller and I saw it on a snap on book with the snap on logo and looks exactly the same.....maybe they are?????????????
Twelvoltz
Posted: November 22, 2007 at 10:15 AM / IP Logged
I have tried that cold heat thing. I guess it would work for board electronics but in my opinion it is crap. As far as the iron getting "too hot" the iron/gun you choose should offer a variable temperature setting. Weller is a very good brand, I have used their irons for various jobs for years with no complaints. As far as a butane/cordless iron goes the Snap-On iron I have currently (see above post) has never let me down other than the life expectancy of the tips but you can order replacement tips from Snap-On.com so you don't have to wait for the truck to come around. The local Snap-On guy here sometimes stops once a week, sometimes not for months. I assume that someone like Weller makes the Bluepoint/Snap-On iron that I have but I have not found anyone that has one that looks identical yet. I have found a few variations that look similar, but none that look identical.
another-kelly
Silver - Posts: 618
Posted: November 22, 2007 at 11:21 AM / IP Logged
My RadioShack torch
i use this one from radioshack. only $20 bucks, has an iron tip and a torch tip. only complaint is the igniter is separate and not built in. other than that i love the thing
Posted: November 22, 2007 at 12:55 PM / IP Logged
I used to use that Snap-on /Bluepoint  at $200 in UK untill I discovered that Radiospares (a nationwide electronics distributing company and Maplin -think Radio Shack UK) were both selling it for about $80!
I've used Weller Gas Irons ever since, also Weller Gun which is useful with its tip illumination; but the gas iron runs hotter!  I have found that once the first tip dies you have constant problems with the gas irons, you must be patient.
metalface427
Posted: November 24, 2007 at 6:27 PM / IP Logged
The weller SP80L solder iron from orchard supply works very good for me i think its the 80 watts model.
ibasspro
Copper - Posts: 95
Posted: November 24, 2007 at 8:25 PM / IP Logged
Mine is call "THE POWER PROBE" LOL seriously, got it off either the MAC or MATCO truck 5 or so years ago, go it as a funny, but it works really well. I use the butane from the local stop N rob, & have never had a problem.
used to be loud, used to be fast...now I am married LOL
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
