engine shuts off when alarm is disarmed
yfz4fitty
Member - Posts: 8
Posted: December 02, 2007 at 1:34 AM / IP Logged
I just installed a firesun/prostar gold 2-way alarm/remote start in my 99 dodge ram. When I start my truck with the remote start then disarm my alarm it shuts off the engine, I cannot remote start the truck without the alarm being armed either.. I don't know if this is normal for this alarm/remote start or not, but my last setup was a 791xv in a 98 cadillac sts and I could remote start it, disarm the alarm and it would stay running... Any help would be greatly appreciated. engine shuts off when alarm is disarmed -- posted image.
yfz4fitty
Member - Posts: 8
Posted: December 07, 2007 at 6:40 PM / IP Logged
Anyone have any Ideas???
peterubers
Silver - Posts: 706
Posted: December 07, 2007 at 7:16 PM / IP Logged
This is not normal for a traditional r/s-alarm unit...
1) who installed it? Can you take it back?
2) If all wiring is installed correctly (i.e. no relays are tripping/interrupting ignition wiring via the arm/disarm), then the brain seems to be either 1) incorrectly programmed, or 2) defective
I've never worked with the above type of remote starter
The search function is your friend.
tedmond
Gold - Posts: 4,610
Posted: December 07, 2007 at 7:46 PM / IP Logged
sounds as if u had the ignition killed wired wrong. did u wire it so when disarmed there would be continuity? becasue some units have ground out when armed, some other units have ground out when armed (constant) and its not like ground when running.
yfz4fitty
Member - Posts: 8
Posted: December 07, 2007 at 7:57 PM / IP Logged
Thanks for the replies.. I installed it myself but I have done several alarms and remote starts, so this kinda boggles me.. The thought of the Starter kill Relay being wired incorrectly Has me thinking.. I know it does work, I have tried starting the Truck when it is armed and it does kill the starter, And the truck starts perfectly fine when disarmed.. I'll try unhooking the starter kill relay and see if it works properly then...
yfz4fitty
Member - Posts: 8
Posted: December 07, 2007 at 8:18 PM / IP Logged
I thought about it for a second and the only relay I have in the system is for the starter disable which only controls the starter wire so that shouldn't have any affect on my problem.. I'm wondering if it has something to do with the acc. (key input wire) wire possibly.. here's a link to the install manual for my alarm.. FireSun Alarm/Remote Start Install   And It's installed in a 1999 Dodge Ram Sport..
peterubers
Silver - Posts: 706
Posted: December 07, 2007 at 9:33 PM / IP Logged
i read through the manual... nothing i read applies to your problem... i think you may have a defective brain -- disarming should have NOTHING to do with the remote starting feature
yfz4fitty
Member - Posts: 8
Posted: December 07, 2007 at 9:46 PM / IP Logged
Ok Thanks a lot I'm gonna contact the company I bought it from and see if they will Exchange it...
tedmond
Gold - Posts: 4,610
Posted: December 08, 2007 at 8:06 AM / IP Logged
yea i looked at the manual still. nothing thatshould be causing that problem.
yfz4fitty
Member - Posts: 8
Posted: December 08, 2007 at 7:02 PM / IP Logged
Well I bought it off Ebay and the user I got it from is no longer a registered user go figure.. So I guess Im stuck with it.. It really ain't no big deal its just gets a lil annoying.. But I'll learn to deal with it...   Thanks everyone for the replies!!! engine shuts off when alarm is disarmed -- posted image.
