2006 gmc sierra 2500 1700g
mbaudio06
Copper - Posts: 60
Posted: December 12, 2007 at 2:58 PM / IP Logged
Anyone use this module on this particular vehicle? Also I dont have access to Directech.com any more so Im assuming the wire colors for this truck are the same as the 1500?
cutter1122
Copper - Posts: 103
Posted: December 13, 2007 at 7:00 PM / IP Logged
12 VOLT CONSTANT  (2) RED (+)   IGNITION SWITCH HARNESS
 STARTER YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
 IGNITION 2 WHITE (+) See NOTE *6 IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 ORANGE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GRAY/BLACK (-)  @ BCM, BROWN Plug, Pin B2, See NOTE *1
 PARKING LIGHTS ( + ) BROWN (+)  IN DRIVERS KICK PANEL
 POWER LOCK See NOTE *4
 POWER UNLOCK See NOTE *4
 LOCK MOTOR WIRE GRAY (+)  IN DRIVERS DOOR at DOOR MODULE
 DOOR TRIGGER GRAY/BLACK (-) DRIVERS and BLACK/ WHITE (-) PASSENGER, Use both, See NOTE * 2  @ EACH DOOR MODULE in EACH DOOR   14301_FULL-SIZE-PICKUP-_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
 DOMELIGHT SUPERVISION GRAY/BLACK (-)  @ BCM, BLACK Plug PIN F, See NOTE *1
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLACK / YELLOW to BLACK (-)  @ STEERING COLUMN HARNESS
 TACH WHITE  @ PCM, GREEN PLUG PIN 36, See NOTE *3
 WAIT TO START LIGHT DARK BLUE (-) See NOTE *5  @ PCM, See NOTE *3
 BRAKE WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  LIGHT GREEN (-)  IN DRIVERS DOOR MODULE in DRIVERS DOOR
 ANTI-THEFT YELLOW (+), BLACK (-) and RED / WHITE (Not Used)  GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
 NOTE *1 The BCM (Body Control Module) is located UNDER the drivers side of dash. The unit has (6) plugs on it with the PUPRLE Plug on the back of the unit.
NOTE *2 on the BASE model trucks the wires are in the LIGHT BLUE PLUG at the BCM, PINS B4 and B5. On the 4 door trucks the DRIVERS REAR door is a LIGHT BLUE/BLACK (-) PIN A3 and the PASSENGERS REAR DOOR is a LIGHT GREEN/ BLACK (-) PIN A2 these wires are in the the PURPLE PLUG at the BCM.
NOTE *3 The PCM (Powertrain Control Module) is located in the LEFT FRONT of the engine compartment to the left of the fan shroud. On DIESELS the TACH wire is at the BLACK PLUG, PIN 55 and on the hybrid models the tach wire is in a GREEN PLUG PIN 35
NOTE *4 This vehicle will Requires a Anti-Theft Bypass Module Part GMDL-BP to connect the Door Locks and Bypass the PASSLOCK 2 System. If not connecting up the Door locks use the 791 Bypass module.
NOTE *5 when hooking up a remote starter, if you cannot get the (+) or (-) Wait to Start wire on the Remote Starter to work properly, you will then need to disconnect this wire and Program the Remote Starter for the 5, 10, 15 or 20 Second Wait to Start Timmer in the Installation manual.
NOTE *6 IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!!
