Explorer Fuel pump no power
cdawg
Posted: October 12, 2002 at 1:10 PM / IP Logged
My 93 Explorer wouldn't start so after some testing I pulled the  fuel pump.  I tested teh fuel pump and it works but is not getting power at the connector.  I have visually inspected all of the fuses but I don't have the owners manual to see which reference number on the underdash fuse panel goes to which accessory,.  any help would be apprediated.
Platinum - Posts: 12,488
Posted: October 12, 2002 at 2:15 PM / IP Logged
Find the wire that engages the fuel pump and hard wire ( or piggy back ) a new ignition wire to this wire. The fuel pump engages when the ignition is on and so you are only replicating this action with a new igniton wire. Fuse this new connection and place in the fuse box in an empty slot.
cdawg
Posted: October 17, 2002 at 1:11 AM / IP Logged
I did something very similar to your suggestion.  I piggy backed a wire and ran it to direct power with a switch.  I will replace the switch with a relay, when I have the time and fuse it.  I don't have enough room in my fuse block but an inline fuse will do.  I didn't run it direct to the ignition wire because I'm unsure of the current draw and don't want to overload any wires coming into my fuse block.  I just hope that by running a piggy back I don't burn out something in my computer module.  Thank you for the suggestion.
CDawg
SnomanF150
Silver - Posts: 269
Posted: October 18, 2002 at 8:20 PM / IP Logged
did you check the fuel shut off safty switch?
George
David's Car Stereo
Baton Rouge, LA
