flowmaster mufflers
daniel2002p
Silver - Posts: 524
Posted: December 08, 2004 at 1:09 PM / IP Logged
i am considering buying a flowmaster 40 series deltaflow for my 04 tacoma V6 and was wondering if anyone has ever tried these muffles, and how much horse gain I would get and what kind of sound I should expect.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
fuseblower
Silver - Posts: 403
Posted: December 09, 2004 at 1:11 PM / IP Logged
I would say be careful when changing your exhaust system.  Think about what type of sound you are looking for and if you want to hear it over extended periods of times.  Flowmasters used to rely heavily on resonance to get that deep rumble.  If you look at the cut out of the muffler online you can see the design of the muffler.  Pretty close to a straight pipe.  You will probably get a nice horsepower increase but you will also get a running exhaust rumble.  This means that the faster you go the louder the sound will get.
If you can with stand extreme exhaust noise all of the time go for it.   If you are not sure go to your local shop and see if you can get lucky enough to hear a car with the exhaust on it.
danieljaluise
Copper - Posts: 125
Posted: December 09, 2004 at 3:46 PM / IP Logged
   I have a 3.1L V6 with a single exhaust pipe that splits at the end into dual flowmaster 40 series. I imagine that one would be even louder than two, and mine is pretty loud. It gives a good deep sound, almost a V8 sound. I'm looking into sound dampening materials now. It's nice at first, but when you're driving at highway speeds for a long time, it does get annoying. Most V6's with flowmasters on them have a certain range of rpms at which they make everything inside your car resonate. Mine is from about 1700 to 2500 rpm. Anything above or below that and it just sounds like a normal exhaust.    My suggestion is to get the 40 series, because if u get a quieter muffler, its not gonna give u the sound ur looking for and you'll regret it.
Besides, it gives you an excuse to add more amplifiers. flowmaster mufflers -- posted image.
daniel2002p
Silver - Posts: 524
Posted: December 09, 2004 at 6:53 PM / IP Logged
Thanks, and danieljaluise is it like a rumbling sound or just a louder whine, since you said like a V8 I am assuming that you mean the rumble like dodge and older chev V8 have???????????????????????????
    1.8L VVT-i I-4
danieljaluise
Copper - Posts: 125
Posted: December 09, 2004 at 9:03 PM / IP Logged
definitely a rumble, not a whine or fart-can noise like on 4 bangers.   I remember once after I had just gotten the exhaust done, my car was parked in the garage and I was upstairs. All of a sudden I heard a familiar sound which I thought was coming from across the street. I looked out to get a glimpse of my neighbor's '76 corvette because I 'knew' it was coming down the drivway. after about a minute of standing at the window, I thought I was going crazy. Then I realized I had been sitting on my remote starter button and that the sound was coming from my garage.
It's a good sound, a lot better than some honda civic that sounds like a kazoo.
daniel2002p
Silver - Posts: 524
Posted: December 10, 2004 at 10:11 AM / IP Logged
thanks a lot, that was alot of help, I am definently going to get one of them put on my truck as soon as possible.
    1.8L VVT-i I-4
Hymer
Silver - Posts: 695
Posted: December 11, 2004 at 12:40 PM / IP Logged
I recomend going to a custom exahst shop. The power gain ait't much and yes they are a rumble.. But the custom shop will help get exactly what you want.. I'm not a big fan of bolt on exahst I've run into nothing but trouble.... and I can't spell it either..heh
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 8:39 PM / IP Logged
you really wont get a power increase from just adding a flowmaster muffler. You would get anywhere from 10 - 20 horsepower increase if you replace the pipe from the header or catalitic converter back
daniel2002p
Silver - Posts: 524
Posted: December 11, 2004 at 10:02 PM / IP Logged
also, how about if anyone knows what the difference is between the original and delta-flow series, I want as much sound as possible, w/ the sound or rumble heard inside the vehicle.  which one is better for that?
    1.8L VVT-i I-4
Teken
Gold - Posts: 1,492
Posted: December 12, 2004 at 4:11 PM / IP Logged
The overall sound can be changed and affected by the following.
1. Air filter, and port length. If you're running a CAI (cold air induction) this will affect the sound.
2. Headers, whether it be 4-1, 4-2-1 design.
3. Resonantor, is the biggest thing that will *tune* in-out the sound of tin can, to V8 rumble. The ever present Honda fart can sound can be completely eliminated by the proper selection of a resonantor.
I know, because I am using a resonator from a V8 Mustang for my Integra.
Regards
EVIL Teken . . .
Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
