disabling shock sensor whilst car is goin
_deagle_
Member - Posts: 6
Posted: February 20, 2009 at 12:05 AM / IP Logged
Hi there. Just to confirm, would this setup be correct to disable shock sensor whilst turbo timer is still going?
85 - ignition signal from turbo timer
86 - ground
30 from 12V+ from shock sensor
87a to 12V+ shock sensor
Whilst turbo timer is going, it will energize the coil which means there will not be a 12V+ source to power the shock sensor, once the turbo timer is off, it will click back to 87a (12V+) and shock sensor will receive power again.
Cheers.
'00 Subaru B4 Legacy RSK
ckeeler
Gold - Posts: 1,461
Posted: February 20, 2009 at 1:06 AM / IP Logged
yes
Big Dog
Gold - Posts: 1,265
Posted: February 20, 2009 at 9:24 AM / IP Logged
Or you can connect the ground of the shock to ignition out of your remote starter. This works most of the time but you'll have to test it in your installation.
Prepare your future. It wasn't the lack of stones that killed the stone age.
