latched on/off output, 2 momentary inputs
woodsbuggy3
Posted: April 11, 2011 at 10:39 AM / IP Logged
I want to use the circuit below but I need both pulsed triggers to be + instead of - , how would I go about doing that?
latched on/off output, 2 momentary inputs -- posted image.
Posted: April 11, 2011 at 11:11 AM / IP Logged
Make the red wire in the diagram go to ground.
woodsbuggy3
Posted: April 11, 2011 at 11:22 AM / IP Logged
Then what do I do with 85 on the center relay?  just wire it to + ?
I guess I was afraid that would break the latching function?
Posted: April 11, 2011 at 12:25 PM / IP Logged
If you want a negative output leave it as it is, if you want a positive output, make the black in the diagram positive. This isn't rocket science.
woodsbuggy3
Posted: April 11, 2011 at 12:35 PM / IP Logged
I know, its just been a long time since I have done this stuff!  I appreciate your help.
So this is what I want then, right?
hotwaterwizard
Silver - Posts: 1,350
Posted: April 13, 2011 at 12:34 AM / IP Logged
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
the12volt
Administrator - Posts: 3,959
Posted: April 13, 2011 at 12:53 AM / IP Logged
Connect the terminals in the diagram that go to the negative pulses to turn on and off to ground (terminal 86 of the first relay and terminal 85 of the third relay). Terminal 85 of the first relay and terminal 86 of the third relay will no longer go to a constant 12V+ source. Instead, terminal 85 of the first relay will be your positive input to turn on and terminal 86 of the third relay will be your positive input to turn off.
When i get a moment, I'll draw one to add to the database.
latched on/off output, 2 momentary inputs -- posted image. the12volt • Support the12volt.com
the12volt
Posted: April 13, 2011 at 10:54 PM / IP Logged
Posted: April 14, 2011 at 1:36 AM / IP Logged
Er guys were running around in circles here, 12volt and HWW you're both correct but this is what I told the poster to do originally!
the12volt
Posted: April 14, 2011 at 1:42 AM / IP Logged
Howie, read what the op wrote and your replies again. He was asking for positive input pulses. Making the red wire go to ground is not the solution. See the diagram I linked to in my previous post. https://www.the12volt.com/relays/relaydiagram63.html
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
