how to wire to relay
jsxmike
Posted: November 23, 2012 at 6:40 PM / IP Logged
I am trying to connect a Raspberry PI to a relay to control a 12V output.
I have a OMRON G5LA-1 relay.
This is a 5 pin relay. each corner has a pin and one end has a pin in the middle.
The vendor diagram shows them PINS 1-5.
The output driver needs to supply 12V constant output and have a short ground pulse returning back to 12V constant.
I found this diagram for a pulse output: how to wire to relay -- posted image.
Can someone let me know what pins to connect to what?
This is the instructions from the Raspberry PI site that shows good informatin - except what pins to connec to what from the relay:
http://www.susa.net/wordpress/2012/06/raspberry-pi-relay-using-gpio/
Platinum - Posts: 7,827
Posted: November 23, 2012 at 7:43 PM / IP Logged
Here is a link to the OMRON Relay spec sheet : http://components.omron.com/components/web/PDFLIB.nsf/0/4F7D9D9CA026C97E862573930070AC4F/$file/G5LA_E_0911.pdf
The way they have them numbered, looks like pins 2 and 5 are the relays coil.
Relay Pin 2 to Raspberry +5V
Relay Pin 5 to Q1 collector
Relay Pin 3 to AC1
Relay Pin 1 to Motor
Relay Pin 4 not used - insulate
jsxmike
Posted: November 23, 2012 at 7:55 PM / IP Logged
Thank you very much.
jsxmike
Posted: November 23, 2012 at 8:53 PM / IP Logged
I have drawn up what I think is the right way to merge the two diagrams (inputs and outputs) -- to have the output drive a sustaining 12V until the relay is pulsed, then it will drive GND and revert back to the 12V.
The Raspberry PI is trying to control a driveway gate motor for remote control to activate the gate to open or close.  The INPUT line on the Gate Sensor will activate the motor when it detects a GROUND pulse input.
Is this right?
Thank you
Posted: November 24, 2012 at 1:21 AM / IP Logged
Your last diagram is correct.
That Omron unit is the standard SPCO format for PCB relays.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
