If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Tuesday, April 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Solder the diode to the legs of the relay at the base of the leg so you can still slide a connector onto the leg.
