DEI 451M Relay
klotchley
Posted: May 16, 2018 at 8:05 PM / IP Logged Link to Post Post Reply Quote klotchley
Ok, I have instructions for my car reversed polarity door locks. But, the instructions say use a 20 amp fuse. The DEI 451M comes with a 15 amp. What should I do?
Klotchley
geepherder
Platinum - Posts: 3,668
Posted: May 17, 2018 at 3:50 PM / IP Logged Link to Post Post Reply Quote geepherder
You didn't mention your vehicle, but I'm assuming your power locks are fused at 20 amps? It's likely they don't actually draw much more than 10 amps, so a 15 amp fuse is probably okay. The 451M has onboard relays that can handle 40 amps, but it's probably fused at 15 amps due to the smaller wire. I suggest trying the 15 amp fuse and seeing if that works.
klotchley
Posted: May 17, 2018 at 5:40 PM / IP Logged Link to Post Post Reply Quote klotchley
Alright, someone cares. Cool, yeah I think you're right. But, the whole 20 amp thing has me a bit confused. See, I thought the same as you. But, I haven't checked the fuse that protects the parking lights. Reason being is the statement was pertaining to the module. And the thing is refered to as a DEI 451M module. So, I really am assuming thats what it means. In fact, it even says protect the violet/black wire of the module with a 20A fuse. I thought maybe its just a typo. However, I am going to take your advise, because it sounds reasonable. Just to let you know, I own a 93 Mercury Sable GS 3.8L. It has type C door locks with reversing polarity. I bought a ScyTek A20 car alarm. This car has 91,000 original miles and I have spent a good amount of money in repairs/maintenance. So, I decided to try to protect it while I sleep. Thank you, for spending your valued time to help a stranger.
Klotchley
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
