Dual Relay Setup DC Hydraulic Pump
mncountrydoc
Posted: February 28, 2023 at 8:24 PM / IP Logged Link to Post Post Reply Quote mncountrydoc
Hello. I have a Kawasaki mule with a electric over hydraulic dump bed. Father in law pulled the relays since one was bad and didn’t write where wires went, confusing to me is each of the 2 relays had 2 pins that were grounded. Also it has a 3 way switch for up and down, trying to figure out what pins I need to wire to what. I have battery power 2 wires. 4 ground plugs. 2 wires from switch and 2 wires from pump
Platinum - Posts: 13,724
Posted: March 02, 2023 at 10:05 PM / IP Logged Link to Post Post Reply Quote i am an idiot
https://www.the12volt.com/relays/relaydiagram4.html
https://www.the12volt.com/relays/relaydiagram48.html
https://www.the12volt.com/relays/relaydiagram49.html
One of the above links should be what you need.
