LED signal blinks too fast
greedy111
Member - Posts: 24
Posted: March 30, 2004 at 1:09 PM / IP Logged
I've installed led signal lights on my tail lights and now it blinks like a million times per second.  its so fast that the relay doesnt even make a clicking noise anymore.... it just buzzes.  is there a way to make it blink slower without adding a resistor?  i dont need it to blink as slow as it normally blinks, but just slow enough so that i can tell that its blinking.  it blinks so fast now that you cant even tell its blinking.
xetmes
Silver - Posts: 586
Posted: March 30, 2004 at 3:19 PM / IP Logged
i think you can replace the thernal flasher with an electronic one to fix it
its_radio_shop
Copper - Posts: 76
Posted: April 09, 2004 at 2:11 AM / IP Logged
Your right xetmes, there is electronic flashers out there. Use one of those in place of your OEM flasher.
greedy111
Member - Posts: 24
Posted: April 13, 2004 at 3:12 PM / IP Logged
where would i be able to get an electronic flasher?
xetmes
Silver - Posts: 586
Posted: April 13, 2004 at 5:06 PM / IP Logged
i think most automotive shops, like pep-boys, auto-zone.... or mail order...
s0crates82
Posted: April 13, 2004 at 5:32 PM / IP Logged
depends on the car, some don't use standard two/three prong flashers.
for example, the 2nd generation mitsubishi eclipse and other similar DSM's.
the flasher/hazard unit for these is buried behind the stereo and is a wide flat box with a ten pin connector.
go to your dealership's parts dept and ask them to look up where your flasher is, and get a print out if possible.
You sold me queer giraffes, I want my money back.
s0crates82
Posted: April 14, 2004 at 4:12 PM / IP Logged
you could also wire in a 3 ohm 20-25w resistor in parallel with your turn signal bulb, that way, to the flasher, your bulb is still there.
