pulsed to timed
robbie2883
Copper - Posts: 104
Posted: April 15, 2004 at 10:53 AM / IP Logged
i have been racking my brain trying to figure out how to take a 1 second pulse and turn it into a timed output for a bosch relay.  i know they make timed relays, but all the ones I find are like 50 and 75 bucks. I don't feel like spending that much. i'd like to just make it using some caps and resistors if possble. Thanks for any help.
if its jammed force it - if it breaks in the process it needed to be fixed anyway
pulsed to timed -- posted image.
xetmes
Silver - Posts: 586
Posted: April 15, 2004 at 11:07 AM / IP Logged
what do you want it to do?
After a pulse stay on fo a certain period of time?
robbie2883
Copper - Posts: 104
Posted: April 15, 2004 at 3:15 PM / IP Logged
yeah...about 10 seconds or so
markcars
Silver - Posts: 662
Posted: April 15, 2004 at 4:15 PM / IP Logged
Use a 555 timer. One of the most versatile timers I have ever used. Options are almost limitless.
robbie2883
Copper - Posts: 104
Posted: April 15, 2004 at 10:35 PM / IP Logged
i've heard about these. they have them at radio shack right? can you give me any info on how to wire it up? it's an intigrated circuit right?
xetmes
Silver - Posts: 586
Posted: April 16, 2004 at 6:25 AM / IP Logged
its a small IC that can be used in a monostable set-up. here is a  circuit and timing calculator. You may want to add a transistor to the output to drive a realy.... They can operate at 12V as well, no need to drop the voltage down.
robbie2883
Copper - Posts: 104
Posted: April 16, 2004 at 6:51 AM / IP Logged
thanks man....that will work. one thing though.....will the output be + or -?
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
