pop trunk
CutlassThunder
Copper - Posts: 68
Posted: June 26, 2004 at 12:11 AM / IP Logged
I'm tryin to do a custom pop trunk not just the old trunk release I want to be able to press a button and the trunk fully opens...but to do this I would need some type of timers or something to activate the actuators a few seconds after the lock has been released how do I do this?
Teken
Gold - Posts: 1,492
Posted: June 28, 2004 at 9:55 PM / IP Logged
It would be easier to simply use springs or gas pressured shocks / struts, then using a actuator.
Just another idea . .
Regards
EVIL Teken . . .
Installerny99
Member - Posts: 30
Posted: August 12, 2004 at 10:01 PM / IP Logged
Depending on your alarm you can use a validity output, so as long as you hold the button it will keep that circuit energized , most of the DEI products will have a validity out , or you can set it up on a latched relay hit the button once it lactches sending power and then hit it again to stop it, i would use validity for that. hope that helps.
goog luck
InstallerNY99
dBDevil
Copper - Posts: 38
Posted: August 14, 2004 at 11:59 PM / IP Logged
Using the validity would be an option, but it would burn the actuator out in a short time. Holding the button to activate the lifts would also hold the actuator pulling, burning the motor.
Monday, August 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
