How do I wire for a motorized amp rack?
scorponox
Posted: July 19, 2004 at 3:42 PM / IP Logged
I will use window motor to move my amp rack...but I would like to know how to wire it.  I think I need 2 relays and 2 limit switches....any schematics?
Is there any other way to wire it up with a window module?
scorponox
Posted: July 19, 2004 at 3:51 PM / IP Logged
I fogot to add that I would like the rack to slide out when the trunk  opens and then when the trunk is closed the rack slides back.  The trunk has a switch that grounds in order to turn on the trunk light....so I was thinking to use this switch to control the amp rack.
auex
Platinum - Posts: 5,041
Posted: July 22, 2004 at 12:10 AM / IP Logged
There actually is a good article on basic motorization that would probably help you out in the september issue of CA&E. When I can find a link to the article then I will post it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
ropes
Posted: July 25, 2004 at 7:21 PM / IP Logged
I saw your question and I was intrigued...and I think I have figured it out.  The way I figure, you would have to use three relays...one that runs off the trunk switch and two for polarity reversal.  You'll see what I mean in the diagram...
How do I wire for a motorized amp rack? -- posted image.
All you would have to do is figure out where to phisically put the limit switches so that the motor stops moving your rack setup.  Hope this helps.
ice4life8269
Copper - Posts: 112
Posted: August 03, 2004 at 6:23 AM / IP Logged
scorponox, did you try it yet? i'm interested to see your progress
swede
Copper - Posts: 125
Posted: August 08, 2004 at 10:39 PM / IP Logged
Is there a place to buy adjustable actuators or is using window motors usually the norm?
Subtlety is EVERYTHING.
scorponox
Posted: August 15, 2004 at 11:24 PM / IP Logged
IT WORKED...THANKS ROPES.
It works like a charm. But now I have a problem...the motor spins too fast and I need to slow it down.  How do I do this...with a resistor?
promodeepcycle
Copper - Posts: 152
Posted: August 31, 2004 at 11:49 AM / IP Logged
i just finished doing some motorization yesterday  ..used 2 pulse timers 2 relays and a reed switch ...lifting the hatch on a 88 civic hb turned out pretty good
dont be a pet monkey ..use your dmm
Asmodeus
Silver - Posts: 393
Posted: September 02, 2004 at 11:23 PM / IP Logged
Fishman Car Audio sell good Linear Actuators that I have used on numerous occasions....They are smooth actuating and are REAL Strong...
I am sure that most any Linear Actuator would be just as good..I have just been dealing With Fishman Custom Car audio accesories and like their business....They have all kinda stuff for doing custom installs....
Making the World A Louder Place
hotwaterwizard
Silver - Posts: 1,350
Posted: September 08, 2004 at 9:35 PM / IP Logged
Look what I found as a Starting place.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
