Starter kill
gmc92sierra
Member - Posts: 21
Posted: October 20, 2004 at 8:09 PM / IP Logged
I bought a starter kill awhile ago and looking at the relay, it just doesn't look right.
On 86 wire going to Alarm    -      On 87a wire going to Starter
On 85 wire going in conjunction to  wire 30 going to Starter(keys)  with diode going from 86 to 85.
Is this starter kill right?  I've been seeing all sorts of starter kills but none like the one I have.
Help me out.
hotwaterwizard
Silver - Posts: 1,350
Posted: October 20, 2004 at 11:38 PM / IP Logged
Look at these Diagrams
https://www.the12volt.com/relays/page2.asp#sk1
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
vancouverbc
Copper - Posts: 72
Posted: October 22, 2004 at 1:08 AM / IP Logged
diode between 86 and 85 is an integral part of relay to avoid voltage spike from coil deenergizing.
1991 240sx
alarm=model 2620.web central door locking system
sm951
Member - Posts: 25
Posted: October 22, 2004 at 9:16 AM / IP Logged
Questions about diodes from a newbie:
-Do you solder the diode directly to poles 86 and 85?
-Also, after soldering a diode into a wire (one), what's the best way to prevent the hard metal leads of the diode from breaking off?  It seems like they're fragile.  Is there some kind of protector you could put over the diode, like a heat shrink tubing, or does it need room for heat dissipation?
Thanks!
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
