120 volt applicaitons?
Lowron
Member - Posts: 23
Posted: December 18, 2004 at 12:29 AM / IP Logged
Im trying to wire a 12 volt switch to a set of 120 volt flourscent lights. Trick is that the switch has a 12 volt light in it. I figured I would use a relay. Is this possible?? I want the switch to light up when the lights come on. Do I need special relays for this?
2intrigues
Member - Posts: 8
Posted: December 26, 2004 at 11:46 PM / IP Logged
If the switch has a 12 volt incandescent light in it, you can use a small 12.6 volt filement transformer to convert the 120 VAC power being applied to the flourescent lights to 12.6 VAC for lighting the switch (AC or DC doesn't matter for incandescent lamps).  If the switch light is actually an LED, you will need to put a diode (like a 1N4007 in series with the transformer output.
You should be able to find a suitable transformer in Radio Shack.
2intrigues
Member - Posts: 8
Posted: December 26, 2004 at 11:52 PM / IP Logged
Here's a link for a transformer...
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F016%5F000&product%5fid=273%2D1365
Of course, it might just be simpler and cheaper to replace the switch with something using a 120VAC neon light (if a lit swich is important to your application).
2intrigues
Member - Posts: 8
Posted: December 27, 2004 at 8:46 AM / IP Logged
If you want, you can use a relay with a 120VAC coil.  Just wire the coil of the relay in parallel with your flourescents.  Wire 12 VDC through the N.O. contacts of the relay to the light in the switch.  Here's a link to a suitable relay from Radio Shack...
  http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F013%5F000&product%5fid=275%2D217
Lowron
Member - Posts: 23
Posted: December 27, 2004 at 10:44 PM / IP Logged
Thanks for the links!
Thursday, October 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
