relay trick's
techker
Copper - Posts: 70
Posted: October 17, 2002 at 5:20 PM / IP Logged
i need to know if any body has trick's that they whant to share with me?
like ,a timer relay(with 2 relays)
sound systeme turn on(i know it but not shure)
and other cool tricks!
techker
djfearny2
Silver - Posts: 810
Posted: October 17, 2002 at 6:20 PM / IP Logged
what do you mean sound system turn on. you mean to boost power of remote or something or what .
Jon
Installer/Help Technician
---coral springs florida---
techker
Copper - Posts: 70
Posted: October 17, 2002 at 6:28 PM / IP Logged
no to turne on systeme by remote(alarm)
techker
tuttz
Member - Posts: 7
Posted: October 20, 2002 at 12:10 AM / IP Logged
you can connect a dei pulse timer relay btw the warn away output of a motion sensor and a window roll up module to roll up your windows when someone gets too close to your car , tutz
tuttz
djfearny2
Silver - Posts: 810
Posted: November 03, 2002 at 10:29 AM / IP Logged
tuttz has something totally different.  how long do you want to keep system on and well there is a little device made by ? available at autozone that is by remote and there use is for fog lights but you can use it for this , its a little box with like four wires comming out from it a antenna and 12 volt constant a ground and an output the out put whould go to the acc wire of the radio a lot less current than a pair of fog lights so you should be ok, fuse it anyways on both ends 12 constant and output wire., just take an extra minute or two.
Jon
