Posted: May 10, 2005 at 12:34 PM / IP Logged
Posted: May 10, 2005 at 8:19 PM / IP Logged
Posted: May 12, 2005 at 8:38 AM / IP Logged
Friday, May 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The neons will be supplied with ground from a connection bolted to the chasis.
How do I wire up a relay to supply +12volts activated by the latched negative aux channel from my alarm? Also do I need to use any diodes?
Any help much appreciated thanks.
, that diagram sorted my mini install.
Also does it matter if pin 86 is the negative input and 85 the fused 12v constant?
Thanks Mo.
