JDM Folding Mirrors
jays_z
Posted: December 05, 2005 at 8:06 PM / IP Logged
Hello guys im prettty new here and im in need of your assistance.I have searched but none of the other questions helped me out. I just installed a set of Jdm folding mirrors on my car, now i want them to work with my alarm. When I arm I want them to close when I disarm I want them to  open.here's the problem when i switch to close them the left side is positive and the right side mirror is negative. and when i switch to open them vice versa. what im looking for is relay that puts out both a positive and a negative output. and vice versa.
infinkc
Copper - Posts: 438
Posted: December 06, 2005 at 7:42 PM / IP Logged
how do you have them wired up? are you using the factory wiring and relays? if so you should be able to tap into the Blue / YELLOW wire to simulate pressing the switch, with only one voltage
There are 10 types of people in the world, ones that understand binary and ones that dont.
jays_z
Posted: December 07, 2005 at 8:50 PM / IP Logged
if i did that that i believe only one side will close. I need a negative output for the otherside for it to close
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
