converting 200mA to 500mA
j68rh
Copper - Posts: 147
Posted: January 31, 2006 at 7:27 AM / IP Logged
How is a relay wired to up my trigger out from the alarm from 200mA to 500mA
KarTuneMan
Platinum - Posts: 7,056
Posted: January 31, 2006 at 9:30 AM / IP Logged
87 ground, 86 12volts, 85 your excisting neg trigger, 30 your new trigger
KPierson
Platinum - Posts: 3,527
Posted: February 04, 2006 at 10:26 PM / IP Logged
If you use a relay you'll most likely convert from 200mA to 20 or 30A.  If you really only want 500mA you'll need to use a transistor, not a relay.  However, the relay approach would be easier, and in the long run more reliable.
Kevin Pierson
