Genral relay ?
napier
Posted: February 26, 2006 at 8:08 PM / IP Logged
ok, This is kind of a stupid question ,but im not understanding.  When using a spdt relay to switch ONE accesiory such as a light or fuel pump or what not.  you run the power to the coil and the ground to the other side of it .  Then the accesory to the n/o if its normally on right?  What do u run to the normally closed and common terminals?  Sorry for such a basic question .
sparkie
Platinum - Posts: 2,061
Posted: February 26, 2006 at 8:48 PM / IP Logged
Terminal # 85 goes to ground and #86 to a switched source of 12 volt+. You can also use a switched source of ground to activate the relay and connect terminal # 86 to a constant 12 volt+ source. Terminal # 30 goes to a fused source of 12 volts + and terminal # 87 to the accessory you wish to power. Terminal #87a is not used to simply turn on/off a device.
sparky
napier
Posted: February 26, 2006 at 8:57 PM / IP Logged
ok, so does this sound right?
85 ground
86 switched 12v
30 to  a constant fused 12v??
87 to accesory?
87a not used?
sparkie
Posted: February 27, 2006 at 1:51 PM / IP Logged
Yup. Now you got it.
sparky
judge
Posted: April 19, 2006 at 8:33 PM / IP Logged
looking for the kill switch relay on a 95 gmc jimmy need help finding it
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
