Remote Turn On Fuses
crono61
Member - Posts: 7
Posted: August 02, 2006 at 8:29 AM / IP Logged
would i really need to fuse all of the output wires in a setup like  https://www.the12volt.com/relays/page5.asp #5? or would just the one fuse from the 12v source be sufficient?
oscarnl86
Copper - Posts: 84
Posted: August 02, 2006 at 10:26 AM / IP Logged
just to be safe fuse both the 12v source and the output. you dont realy need to fuse the output but like i said you might wana do it just to be safe
supersix4
Copper - Posts: 71
Posted: August 02, 2006 at 10:43 AM / IP Logged
Each device you run off that relay should be fused, just like the diagram shows.
Protect your gear & vehicle. Fuses are cheeeeeeeep insurance, man. Consider this ... suppose you are running a few fans, like the diagram shows. One fan fails - dead short. If the only fuse in place is the one supplying the relay on the 87 leg, then EVERTHING else dies too - all the other fans. Now your amp overheats & it starts to act up & eventually dies as well ... maybe even sets your car on fire! All because a silly fuse was not put in place.
crono61
Member - Posts: 7
Posted: August 02, 2006 at 1:04 PM / IP Logged
good advice...thanks guys
