Basic Relay Wiring
monkeytom83
Posted: January 18, 2003 at 2:24 AM / IP Logged
Hi...
Sorry for asking such a simple question but this one is bothering me.
I want to install some relays for power locks. However, the only thing I have installed so far in my car is a new stereo, amp and speakers. When suppling a +12V to the amp, I ran a seperate wire from my battery. For these relays, can I get the +12V from some where else in the car instead of a direct connection to the battery?
Thanks,
Tom
auex
Platinum - Posts: 5,041
Posted: January 18, 2003 at 3:17 PM / IP Logged
You can take it from any power source that is fused with at least 15 amps.  I would recommend taking it from the ignition harness with a fifteen amp fuse inline.  Also what will be controling the relays, 3 position switch, alarm, momentary switch?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
monkeytom83
Posted: January 18, 2003 at 6:44 PM / IP Logged
Thanks for your reply
The relays will be controlled from a Clifford Arrow 3 Alarm. Does this change where I should take my +12V from?
