Intercooler Sprayer Wiring
aboothman
Member - Posts: 8
Posted: December 17, 2006 at 8:13 PM / IP Logged
OK, so here is my situation. I am installing an Intercooler Sprayer setup in my 06 Subaru WRX.
Here is the stock IC sprayer scematic from a STI:
Stock IC Sprayer Scematic
Here is the scematic I used for my setup.
Auto Spray switch and Boost Pressure switch added
I do not have the factory IC Spray timer.
It appears that it is a switched negative circuit, but I could be wrong. My first scematic below is what I came up with from all the searching I have done on the topic.
I have all the parts ready, and I have a couple wiring scematics to go by. However, they do not work. Here are the two scematics that I have:
Scematic #1
Scematic #2
Both circuits make use of a parallel design using 2 switches: First is a momentary switch that sprays as long as I hold it down. I will eventually find an adjustable timer, so if you have any leads on something that will work I would appreciate it.
The second switch is an on/off switch, and arms the boost pressure switch that is installed in my boost gauge vacuum line.
In my limited experience, my issue with the first scematic is the lack of a ground on the relay. I dunno if this is a problem.
I am also curious if the relay will be a power drain on my battery since it will be directly connected.
I have tried both scematics, and neither works. I have checked all fuses, connectors, ect. I am currently using the multimeter to make sure everything is what my reference scematics say it is.
Thanks for any help.
aboothman
Member - Posts: 8
Posted: December 17, 2006 at 8:42 PM / IP Logged
bad links for scematics 1 and 2. Updated:
Scematic #1
Scematic #2
hotwaterwizard
Silver - Posts: 1,350
Posted: December 19, 2006 at 9:16 AM / IP Logged
It looks like you can use a standard Relay until you find your timer.
Intercooler Sprayer Wiring -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
aboothman
Member - Posts: 8
Posted: December 19, 2006 at 8:41 PM / IP Logged
I should fix my original pics, and add another that shows the back of the switch:
My Scematic #1
My Scematic #2
Switch Pin Out
aboothman
Member - Posts: 8
Posted: December 19, 2006 at 8:43 PM / IP Logged
Wish I could edit my posts here....
anyway, I forgot to ask how I can determine what pins do what on the switch?
I KNOW that pin 2 and 4 are correct, but there are many other opinions on what the others do.
hotwaterwizard
Posted: December 19, 2006 at 10:29 PM / IP Logged
Pin 85 is a ground not a hot. It will not work with hot on both sides of the coil of the relay.
Stockton California
aboothman
Member - Posts: 8
Posted: December 19, 2006 at 10:32 PM / IP Logged
ok I got it fully figured out now. Thanks for your help!!
If hindsight it was so blatently simple I am embarassed.
hotwaterwizard
Posted: December 19, 2006 at 10:36 PM / IP Logged
Are you sure you got it?
Stockton California
aboothman
Member - Posts: 8
Posted: December 19, 2006 at 10:44 PM / IP Logged
latest version:
hotwaterwizard
Posted: December 19, 2006 at 10:50 PM / IP Logged
This switch? Is it a slider switch a 3 way switch ? Want more info on it
Stockton California
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
