power mirror motor
riggz
Member - Posts: 20
Posted: September 30, 2007 at 4:23 PM / IP Logged
I installed some newer style power mirrors on my truck and it appears the left/right adjustment motor is reversed compared to my original mirrors. When I try to adjust the mirror to the left, it moves right, when I try to adjust it to the right, it moves to the left. I'm stumped on how I can reverse this so that the mirror switch operates correctly.
Both sides have a yellow wire and 2 different colored wires each. Here's how one mirror's wire work with the switch:
Wire Colors: Y=Yellow P=Purple G=Green
UP: Y(-) P(+) G( )
DOWN: Y(+) P(-) G( )
LEFT: Y(-) P( ) G(+)
RIGHT: Y(+) P( ) G(-)
I've searched and have been unable to come up with a definative answer. Any help is greatly appreciated!
Thanks!
-=riggz
Platinum - Posts: 13,725
Posted: September 30, 2007 at 5:52 PM / IP Logged
Can you get to the 2 wires that connect to the left/right motor?   If so, you will need to reverse the wires there.
riggz
Member - Posts: 20
Posted: September 30, 2007 at 7:17 PM / IP Logged
Not possible. The mirror is sealed and I don't want to risk breaking it by trying to pry it apart. I know someone who  tried to do this very thing and broke the mirror into pieces trying to get at the motors.
-=riggz
riggz
Member - Posts: 20
Posted: October 25, 2007 at 12:44 AM / IP Logged
Just in case anyone reads this and might be able to help out, here's the equation I need to solve:
If Y=(-) and G=(+) make Y=(+) and G=(-)
and
If Y=(+) and G=(-) make Y=(-) and G=(+)
-=riggz
riggz
Member - Posts: 20
Posted: October 25, 2007 at 12:53 AM / IP Logged
Oh and just to clarify, the polarity can only be reversed when the Green (G) wire is either + or -. If it is neither then the polarity needs to stay the same.
-=riggz
