2005 pontiac aztec stereo
craig1998
Posted: February 28, 2008 at 3:14 AM / IP Logged
Do you have information on an '05 Aztec stereo wiring guide?
thanks!
sparkie
Platinum - Posts: 2,061
Posted: March 01, 2008 at 4:06 PM / IP Logged
Buy a proper wiring adaptor kit for this vehicle. The factory radio is a Class II data unit. You need a module to properly integrate an aftermarket radio and to obtain a switched ignition source. The modules derive a ignition circuit from a Class II signal and also retain the door chimes. If you have Onstar, then get a module that will also handle converting it as well. The modules take all the mystery out of wiring in a new radio.
sparky
