2007 Chrysler Sebring, Alarm/Stereo Wiring
rickvl
Member - Posts: 8
Posted: March 29, 2008 at 3:28 PM / IP Logged
need stereo wiring color code guide for 2007 chrysler sebring 4dr sedan 4cly.
Twelvoltz
Platinum - Posts: 2,384
Posted: March 29, 2008 at 6:29 PM / IP Logged
Audiovox lists:
          #512283: 2007 CHRYSLER SEBRING 4DR SEDAN WITH 2.4L ENGINE AND 6-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / BROWN          (+)          RADIO HARNESS
     Accesory          (CAN DATA BUS)
               THIS VEHICLE USES THE CAN NETWORK FOR ACCESSORY TURN ON
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          (CAN DATA BUS)
     Dimmer          (CAN DATA BUS)
     Power Antenna          GRAY/ORANGE          (+)          RADIO HARNESS
     Amp Turn On          (CAN DATA BUS)
     LF Speaker (+)          GRAY/PURPLE
               RADIO HARNESS OR AMP BEHIND GLOVEBOX. WITH AN AMPLIFIER, THE TWEETER WIRE IS GRAY/ORANGE.
     LF Speaker (-)          GRAY / YELLOW
               RADIO HARNESS OR AMP BEHIND GLOVEBOX. WITH AN AMPLIFIER, THE TWEETER WIRE IS GRAY / YELLOW.
     RF Speaker (+)          DARK GREEN/ VIOLET
               RADIO HARNESS OR AMP BEHIND GLOVEBOX, WITH AN AMPLIFIER, THE TWEETER WIRE IS GRAY/DARK GREEN.
     RF Speaker (-)          DARK GREEN/ YELLOW
               RADIO HARNESS OR AMP BEHIND GLOVEBOX. WITH AN AMPLIFIER, THE TWEETER WIRE IS GRAY/LT. GREEN.
     LR Speaker (+)          DARK GREEN/ TAN
     LR Speaker (-)          DARK GREEN/ GRAY
     RR Speaker (+)          DARK GREEN/ BROWN
     RR Speaker (-)          YELLOW/GRAY
     Amp Location          BEHIND GLOVEBOX
     Security
     Battery          RED / TAN (10A)          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW/VIOLET          (+)          DRIVER FENDER (NOT FOR REMOTE START)
               NOT FOR REMOTE START,
     All Door Trigger          USE DOOR TRIGGERS          (-)          MUST DOUBLE DIODE ISOLATE
               YOU MUST DIODE ISOLATE ALL TRIGGERS TO MONITOR ALL DOORS.
     Domelight Super          YELLOW/WHITE          (+)          DRIVER KICK PANEL
     LF Latch          VIOLET          (-)          DRIVER KICK PANEL
     RF Latch          VIOLET/WHITE          (-)          PASSENGER KICK PANEL
     LR Latch          VIOLET/GRAY          (-)          DRIVER KICK PANEL
     RR Latch          VIOLET / YELLOW          (-)          PASSENGER KICK PANEL
     Trunk Trigger          VIOLET/ORANGE          (-)          DRIVER KICK PANEL
     Hood Trigger          VIOLET/LIGHT BLUE          (-)          AT VEHICLE HOOD PIN SWITCH
     Alarm Disarm          FACTORY REMOTE ONLY
     Alarm Arm          ARMS ON LOCK WITH DOOR OPEN
     Parking Lights          WHITE/ VIOLET          (+)          DRIVER KICK PANEL HARNESS
     Low Crr Pk Lights          N/A
     Convenience
     Headlights-Lo          SEE NOTE          (+)          AT THE HEADLIGHTS
               WHITE/ DARK BLUE (LEFT SIDE), WHITE/ TAN (RIGHT SIDE)
     Wipers-Lo          BROWN / WHITE          (+)          AT VEHICLE WIPER MOTOR
     Wipers-Hi          BROWN / ORANGE          (+)          AT VEHICLE WIPER MOTOR
     Parking Brake          DARK GREEN / WHITE          (-)          AT THE BRAKE SWITCH
     Trnk Release          LT.GREEN / WHITE          (-)          AT THE SWITCH
     Remote Start
     Accessory 1          SAME AS SECOND STARTER WIRE
               ACCESSORY IS NEGATIVE TRIGGER THRU A 610 OHM RESISTOR.
     Starter 2          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               STARTER IS NEGATIVE TRIGGER THRU A 180 OHM RESISTOR.
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          SAME AS SECOND STARTER WIRE          (-)          IGNITION SWITCH HARNESS
               KEY SENSE IS NEGATIVE TRIGGER THRU A 8500 OHM RESISTOR.
     Tachometer          UNCOMMON WIRE AT FUEL INJECTOR
     Speed Sense          DARK GREEN/ BROWN          (AC)          AT THE PCM
               PIN 32 ON THE 6 CYLINDER MODELS, IT IS IN THE BLACK/ GREEN PLUG. PIN 89 ON THE 4 CYLINDER MODELS, IT IS IN THE 96 PIN PLUG.
     Low Crr. Pk Lights          N/A
     Brake Lights          DARK GREEN / WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ GREEN          (+)          IN HARNESS IN DRIVERS DOOR SILL
     Horn          GREEN/ VIOLET          (-)          SWITCH OR CLUSTER, PIN 10, BLACK 20 PIN PLUG
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          GRN/DARK GREEN OR GRN/VIOLET          (-)          DRIVER KICK PANEL
               MUST USE RELAYS. UNLOCK IS NEGATIVE TRIGGER THRU A 100 OHM RESISTOR. LOCK IS NEGATIVE TRIGGER THRU A 330 OHM RESISTOR.
     PowerLock          SAME AS UNLOCK          (-)          DRIVER KICK PANE
     Driver Mtr Unlock          TAN/DARK GREEN          (REV)          DRIVER KICK PANEL
     Driver Mtr Lock          TAN/DARK BLUE          (REV)          DRIVER KICK PANEL
     LF Window Up          ORANGE / GREEN          (REV)          DRIVER WINDOW SWITCH IN DOOR
     LF Window Dn          ORANGE / WHT          (REV)          DRIVER WINDOW SWITCH IN DOOR
     RF Window Up          ORANGE / TAN          (REV)          DOOR HARNESS, DRIVER KICK
     RF Window Dn          ORANGE / YELLOW          (REV)          DOOR HARNESS, DRIVER KICK
     LR Window Up          ORANGE / WHITE          (REV)          DOOR HARNESS, DRIVER KICK
     LR Window Dn          ORANGE / GRAY          (REV)          DOOR HARNESS, DRIVER KICK
     RR Window Up          ORANGE / LT. GREEN          (REV)          DOOR HARNESS, DRIVER KICK
     RR Window Dn          ORANGE / BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
rickvl
Member - Posts: 8
Posted: March 29, 2008 at 7:38 PM / IP Logged
Thanks very much!
