93 Honda Accord Wiring - CS2011RS
slappe
Posted: May 30, 2002 at 12:45 AM / IP Logged
Hi!  I have a 93 honda accord SE and a CS2011RS (crimestopper) alarm/remote starter.  i havent really jumped into installing this yet, other than reading the installation instructions.  i think i am going to be needing wiring schematics for my car, unless someone has already installed this alarm on a 93 honda accord before and would be willing to help me out.  the install manual is here
http://www.crimestopper.com/techweb/InstructionBooks/Alarm/cs2011-install-2.pdf
One of the first questions i came up with is... "Connect to the negative horn trigger wire usually located near the steering column.  If the vehicle horn circuit requires +12V, then a relay is required"  does a honda accord require +12V for the horn circuit?  well, if i used my handy-dandy multimeter and ever found the wire, i could test it myself i guess.  maybe thats not such a good question afterall :P
okay - i guess i want to know if anyone else has done this install before, and if they have, do they have any comments or "words to the wise" before i start ripping my car apart.  im a new installer, but i do enjoy projects such as these, and think i should be able to have this thing working quite well, with a little bit of help.  i appreciate anything useful that you would be willing to share.
-SlappE
Platinum - Posts: 12,488
Posted: May 30, 2002 at 5:00 AM / IP Logged
Honda
Accord
1990-1993
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
IGNITION SWITCH HARNESS (HEATER)
Ignition  #3:
N/A
Accessory:
WHITE/ BLACK
Brake  Light:
GREEN / WHITE (+)
AT SWITCH,BRACKET ABOVE PEDAL BRACKET
Tach  Signal:
BLUE
AT DISTRIBUTOR OR DASH FUSE BLOCK
Parking Lights:
BLACK/ RED (+)
HEADLIGHT SWITCH OR AT FUSE BOX
Headlights:
BLUE/RED
(-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
BLUE OR BLUE/WHITE
(-) AT DIS-ARM SWITCH
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Honda
Accord
1990-1993
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
BROWN CONNECTOR ABOVE FUSE PANEL
OEM Horn:
BLUE/RED OR GRAY
(-) STEERING COLUMN HARNESS
Power  Lock:
BLACK/ WHITE
DRIVER KICK PANEL, 2 PIN PLUG TAPPED
Power  Unlock:
BLACK/ RED
TO HARNNESS ABOVE FUSE BOX *
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
* See Note #201 - Negative Pulse Door Lock Diagram.
  • Very basic installation. Make sure that you check the circuit for (-) or (+) input or output and only place the fuse in last just before you try the system out.
  • Open one window in the car before you start the install ( don't want to lock yourself out while testing door locks 93 Honda Accord Wiring - CS2011RS -- posted image.
slappe
Posted: May 30, 2002 at 9:47 AM / IP Logged
Thank you thank  you.  I hope it goes well, but im sure ill be back w/ some more questions.  Thanks.
-SlappE
