1994 silverado steering column wirres
richerie
Posted: July 19, 2008 at 8:25 PM / IP Logged
I am using 94 silverado, 4.3L, auto, steering column in street rod.  Any help in deciphering column wires would be greatly appreciated.
Rich in Erie
Platinum - Posts: 13,726
Posted: July 19, 2008 at 8:49 PM / IP Logged
1994 Chevrolet C/K Pickup Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+Red Ignition Switch Harness
StarterPurple Ignition Switch Harness
IgnitionPink Ignition Switch Harness
AccessoryOrange Ignition Switch Harness
The above are the wires on the ignition switch.  How many other wires are there in the other harnesses?  Are you willing to do a little footwork tracing the other wires to let me know where they go?
richerie
Posted: July 20, 2008 at 7:32 AM / IP Logged
Thanks,
I got the wire clips and here are the color assignments.
There is an 11 position clip containing the following wires and assigned to specific alphabetic positions:
position D:  na
positon E: tan
position F: Lt green
position G: black
position H: Lt blue (double)
position J: Dk blue (double)
position K: brown
position L: purple
position M: yellow
position N: Dk green
position P: white
There is also a 5 position clip having the following alphabet assignment:
position A: na
position B: pink (shunted to position "F")
position C: purple
position D: white
position E: grey
position F: pink (shunted to position "B")
position G: na
Rich in Erie
Posted: July 20, 2008 at 10:08 AM / IP Logged
What controls are on the column?   Blinkers, cruise control, horn,  hi-lo beam switch?   You may need to let me know which wires go to which of the switches.
richerie
Posted: July 20, 2008 at 11:58 AM / IP Logged
Wel, as far as I can tell it contains: horn, wiper motor with intermittent, mist and washer, hi-lo and the ignition.  The color code you gave me is not what I have directy on the column. The major column switch has 4 wires: large yellow (starter?), pink, red and brown.  Also, a 3 wire switch contains red, orange and green (smaller of the 3 wires).  Any help?
Rich in Erie
Posted: July 20, 2008 at 12:51 PM / IP Logged
On the major switch the larger wire is probably the constant wire that feeds the switch.  To find this out you will need to get an ohm meter and put it to the diode test function.  Following is a symbol for a diode.
1994 silverado steering column wirres -- posted image.
Attach one lead to the larger wire and turn the key to the accessory position.  Touch the other lead to the remaining 3 wires (one at a time).  One of these wires should make your meter beep at you.  Turn key off and it should quit beeping.  Label this wire as Accessory.
Turn the key to the run position,  touch the lead to each of the 2 remaining wires, the one that makes the meter beep is Ignition.
Attach the lead to the remaining wire and turn key to start position, if it beeps label it as starter wire.
