2008 ford explorer, seat heaters, power
russbm
Member - Posts: 46
Posted: November 05, 2008 at 9:56 AM / IP Logged
Anyone know the diagram for hooking a relay for this 2008 Ford Explorer the wire is WHITE/ orange and it is a thin wire, and I am installing seat heater on both front seat, and that WHITE/ orange wire is too thin for hot wire. It need to be so that the seater heater come on when the key is switch on and it will turn off when the key is off.
Platinum - Posts: 13,726
Posted: November 06, 2008 at 2:07 AM / IP Logged
Where does the WHITE/ orange wire come from?
russbm
Member - Posts: 46
Posted: November 06, 2008 at 9:50 PM / IP Logged
from the ignition 12volt from the Ignition switch harness
Posted: November 06, 2008 at 10:10 PM / IP Logged
WHITE/ Orange to terminal 86 with a toggle switch in line so you can manually turn the heater off. Ground terminal 85. 30 goes to your battery via a 10 Ga. wire and 20 amp fuse. 87 goes to the heating element of the seat. Ground the other end of the heating element.
russbm
Member - Posts: 46
Posted: November 06, 2008 at 10:31 PM / IP Logged
Ok , but the seat heater has a on and off switch . There 2 wire coming from the seat heater hookup a red and a black , and i use the black for the ground. so that leave me the red wire to hookup to a relay because of the thin wire WHITE/ orange, need so it will turn on the seat heater and when turn the key off the seat heater will not still be on.
Posted: November 06, 2008 at 10:42 PM / IP Logged
WHITE/ Orange to terminal 86. Ground terminal 85. 30 goes to your battery via a 10 Ga. wire and 20 amp fuse. 87 goes to the heating element of the seat. Ground the other end of the heating element.
russbm
Member - Posts: 46
Posted: November 06, 2008 at 10:57 PM / IP Logged
