Correct 2008 Nissan Sentra Remote Start Wiring - FYI
harrodv6
Posted: November 13, 2008 at 4:51 PM / IP Logged
Battery                               Green  Ign. harn
Ignition 1                             Yellow Ign harn
Starter 1                             White ign harn
Accessory 1                     Red ign harn
Accessory 2                      Blue ign harn ( connect if you do defogger option)
Parking light                      Red "+" gray connect, right of fuse box
Brake light                         RED / green at brake pedal switch
Horn                                    dk.green 8pingray connect beside air bag conn pin 3
tach                                     lt.green at coil
Lock                                    red w/ silver dots  driver door harness "-"
Unlock                                 pink w/ silver dots driver door harness "-"
Driver door unlock           GREEN/  YELLOW to green driver kick or BCM Black 15 pin plug, pin 4
E-brake                               green    drivers kick "-"
Clutch                                 BROWN / red  at clutch switch  "+"
Disarm                               red to brown    driver kick or BCM white 40 pin plug, pin 8
Arm                                     blue to white    driver kick or BCM white 40 pin plug, pin 7
Trunk trigger                   WHITE/ green    driver kick
Keysense                         RED / white or purple ign switch harn "+"
DOORS
FL                                          lt.blue drivers kick
RL                                         RED / white drivers kick
FR                                        BROWN / white passenger kick
RR                                      RED / white passenger kick
Rear Defogger               lt.green behind climate control module  "-" 1sec
Reverse Light                 WHITE/ black drivers kick
Can HIGH                          Blue      wires are found at OBDll connector
Can LOW                         Pink
Security LED                   Lt/blue cluster
