2001 Dodge/Plymouth Neon Door Mirror Wiring
cars4sm
Posted: July 31, 2009 at 8:42 AM / IP Logged Link to Post Post Reply Quote cars4sm
I have a Chrysler Neon 2L LX Auto (Right Hand Drive) - same as Dodge/Plymouth Neon 2001 (US model). My drivers's side door mirror got vandalised. I have replaced it with a M3 LED Mirror. I have a problem with the wiring and harness.
The wiring on the M3 mirrrors are as follows:
Blue Wire = Blue LED, White Wire = Orange LED (indicator), Black Wire = Ground.
Green Wire = R to L movement. Yellow wire = L to R movement , White - Ground.
The Chrysler Neon 01 has the following wiring:
1) Black = Heating 2)  Blue/White  = Mirror Horizontal 3) Black = Ground 4) Green = Mirror Unfold 5) BLACK/ White = Mirror Verticle 6) Yellow = Mirror Common - Left,Rightup,Down 7) Light Blue = Mirror Fold.
I have fitted the mirror. I need to know which wires connect with eachother. I have removed the connecting wire harness from the old  mirror which I can use for movement of the mirror.
I need to locate the indicator wire which I think leads to the trunk from underneath the doors.
What's the best way to connect these wires with least hassle. I also need to buy a wire harness if one is availabe for left door mirror.
Your reply/s are appreciated.
cars4sm
sm
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
