99 jeep grand cherokee
cars,inc.
Posted: October 21, 2009 at 10:53 AM / IP Logged
does anyone know which wire to connect the factory disarm wire to from a remote start, keyless entry system
I have the system installed along with the xk531 to bypass the skim module but the vehicle will not stay running and I suspect the factory security is not disarmed correctly
the wiring diagram from here shows a Ltgrn/orange wire in the drivers door lock switch if I am reading right, but I have no wire that color in the switch
thanks in advance
we'll try anything once
Platinum - Posts: 12,488
Posted: October 21, 2009 at 6:44 PM / IP Logged
The XK531 already disarms through data. This doesn't look like it's your problem. When the Jeep tries and dies, does the Immobilizer LED flash ? If so, you do not have the wraps tight enough or not enough around the key cylinder.
XK531 - JDL 1.00 (1999 Jeep Grand Cherokee)
  • W2WAV-Domelight Activation
    AV-Horn Chirp activation
    CC-Power Mirror memory
    CC-Power Seat Memory
    CC-Radio Channel Memory
    DL-Arm Factory Security
    DL-Disarm Factory Security
    DL-Door Lock Control
    DL-Door Unlock
    DL-Driver Priority Unlock
    PK-Immobilizer Bypass-RFID No Key Req'd
    RS-RAP Shut Down (Remote ACC Power)
    SS-Entry Monitoring ALL Door Pins
    SS-Entry Monitoring Front Door Pins
    SS-Entry Monitoring Trunk/Hatch Pin
  • D2DAV-Domelight Activation
    AV-Horn Chirp Activation
    CC-Power Mirror Memory
    DL-Door Unlock
    FOB- CAN alarm control w/FOB remote
    SS-CAN Alarm control w/ FOB remote
    ST-Door Locks Status
cars,inc.
Posted: October 22, 2009 at 7:02 AM / IP Logged
You know now that you mention it I was able to program the xk531, I saw the factory security light on the dash go out after programming the two keys and the xk531, but I have not been able to get into user setup or have I ever seen the led do anything but stay on all the time
will try wrapping the key cylinder again and reprogramming, thank you for your input
