2010 kia soul remote start alarm
visionsss
Member - Posts: 19
Posted: March 13, 2010 at 5:25 PM / IP Logged
I need the wiring for a 2010 Kia Soul. Doing a remote start alarm. Also if there is a bypass module suggestion I would appreciate it. I would like to use the Compustar Blade if it will work.
Fred Kincaid
Visions Sound & Security
GPS Northwest
Platinum - Posts: 7,827
Posted: March 13, 2010 at 8:54 PM / IP Logged
KIA SOUL   2010 -                      Info from Bulldog Security
 PART                                      COLOR                                     LOCATION
 12 VOLT CONSTANT           WHITE (+), 40 AMP                   @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 5
 STARTER                               BLUE (+)                                    @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 1
 STARTER 2                           N/A
 IGNITION 1                           PINK (+)                                       @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 6
 IGNITION 2                           N/A
 IGNITION 3                           N/A
 ACCESSORY /HEATER BLOWER 1  WHITE (+), NOTE #2           @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 3
 ACCESSORY /HEATER BLOWER 2  YELLOW (+)                          @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 4
 KEYSENSE                          N/A
 PARKING LIGHTS ( - )       PINK (-)                                                    @ HEADLIGHT SWITCH, (WHITE, 13-PIN PLUG), PIN 1
 PARKING LIGHTS ( + )     GREEN/ BLACK(+)(Left) and
                                               YELLOW/BLACK(+)(Right), use both!!  @ DASH FUSE BOX, (REAR BLUE, 22-PIN PLUG(I), PINS 17 and 16
 POWER LOCK                   BROWN (-), TYPE B                              in DRIVERS KICK PANEL, (WHITE, 26-PIN PLUG), PIN 10
 POWER UNLOCK               GREEN (-), TYPE B, NOTE #3          in DRIVERS KICK PANEL, (WHITE, 26-PIN PLUG), PIN 18
 DOOR TRIGGER                GREEN (-)                                              in PASSENGER KICK PNEL, (WHITE, 26-PIN PLUG), PIN 16
 DOMELIGHT SUPERVISION      BLUE (-)                                       in DRIVERS KICK PANEL, (WHITE, 26-PIN PLUG), PIN 14
 TRUNK RELEASE              PINK (-), NOTE #4                                in DRIVERS KICK PANEL, (WHITE, 26-PIN PLUG), PIN 1
 SLIDING POWER DOOR         N/A
 HORN                                     GRAY (-)                                              Above DRIVERS KICK PANEL, (BLUE, 39-PIN PLUG), PIN 29
 TACH                                      GREEN, (AC)                                      Above DRIVERS KICK PANEL, (BLUE, 39-PIN PLUG), PIN 17
 WAIT TO START LIGHT        N/A
 BRAKE                                   RED / ORANGE (+)                              Above DRIVERS KICK PANEL, (WHITE, 14-PIN PLUG), PIN 7
 FACTORY ALARM DISARM       GRAY (-) and YELLOW (-) NOTE #5     in DRIVERS KICK PANEL, (WHITE, 26-PIN PLUG), PINS 13 and 23
 ANTI-THEFT  KIA'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1   @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE #1: KIA'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module
 for REMOTE STARTING
 NOTE #2: this wire may need to be RELAY ISOLATED to prevent STARTER GRIND upon KEY take over.
 NOTE #3: to UNLOCK just the DRIVERS DOOR, use the BROWN (-), at the DASH FUSE BOX,
 (REAR WHITE, 20-PIN PLUG(D), PIN 1
 NOTE #4: TEST this wire while Opening the TAILGATE with the Handle on the REAR of the Vehicle.
 NOTE #5: to DISARM, use the GRAY (-) and the YELLOW (-) use both wires, and DIODE ISOLATE will
 Require a Double Pulse. TEST these wires while turning the KEY in the Drivers Door.
Posted: March 13, 2010 at 9:08 PM / IP Logged
As for bypass modules, only Fortin lists their PATS-KIA-1 bypass for the Soul and that would require a dealer scan tool to program.  Looks like it's a key in the box...
Posted: March 13, 2010 at 9:11 PM / IP Logged
iDatalink Tech Support is very good, so you might contact them to see is they have a solution in the works for their Blade cartridge...
fieldtrip
Posted: April 27, 2010 at 7:59 PM / IP Logged
I work in a Dealer in Quebec and here they are only Pats Kia-1 availible for Kia. They are one other possibility it's to put a key in a box... but not much apreciated...
lucasoil4u
Copper - Posts: 317
Posted: May 15, 2011 at 1:25 PM / IP Logged
if you put a key in the box you dont need a dealer scan tool but you do loose a key. you only need the dealer scan tool if you use the tbx kia key.
syl20rochon
Copper - Posts: 298
Posted: May 15, 2011 at 6:58 PM / IP Logged
iDatalink doesn't have a solution if your vehicle is not a PTS. Fortin Patskia or DEI RFLkia2 with the pkdock work great and is less expensive. Key in a coffin is the easiest unless a spare key is not available.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
lucasoil4u
Copper - Posts: 317
Posted: May 16, 2011 at 12:00 PM / IP Logged
How do you realy isolate the ignition wires . All help is greatly apreciated . I id one of these with no bypass . Thanks
How do you get a viper alar to double pulse on disarm?
lucasoil4u
Copper - Posts: 317
Posted: May 16, 2011 at 12:04 PM / IP Logged
What part number diodes do I get from radio shack?
Posted: May 16, 2011 at 12:50 PM / IP Logged
1N4004 for the diodes.
Viper alarm double pulse lock and unlock from the programming.
What do you mean by isolating the ignition?
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
