steering wheel remote complication
scottiefraz
Posted: August 22, 2011 at 8:59 PM / IP Logged
Hello all,
I recently have bought and installed a JVC KW AVX740 into my 2006 chevy silverado 1500. One of my favorite parts is that the truck had steering wheel control and I cant really find whatever I need to connect it all back up. Now the installation booklet shows that it is to be just one while that leads to the ``OE remote adapter``. Now I have noticed that a lot of the systems have a 3.5mm mini plug that connects into the head unit, which this model does not have. Does anyone have a clue or can help me with which module or if I just need to run the wire to a certain wire.. This has been bothering me for days and any help is much appreciated...
Thanks,
Scott
Platinum - Posts: 13,726
Posted: August 22, 2011 at 9:45 PM / IP Logged
chances are if it does not have the 1/8 inch jack, it probably does not support a wired remote.
Posted: August 23, 2011 at 9:46 AM / IP Logged
Bloody non-metric Americans, 3.5mm socket!
casofwaco
Member - Posts: 26
Posted: August 23, 2011 at 2:55 PM / IP Logged
PAC has a universal steering wheel control interface SWI-X. I have used a couple of these, and have had no problem with them except if the sun is hitting on the IR a certian way its an iffy signal. The directions are real easy to follow for any application as long as your head unit has a wireless remote.
BAD Boy Emergency Vehicle Lighting
