98 isuzu rodeo
djerizix
Posted: April 29, 2003 at 10:58 AM / IP Logged
i am looking for the wiring diagram for a 98 rodeo for an alarm, remote start, and keyless entry please.
Thanks.
Platinum - Posts: 12,488
Posted: April 29, 2003 at 11:56 AM / IP Logged
|              12V|white, WHITE/ black  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |-  |DKP white 22 pin connector  |
|     POWER UNLOCK|RED / blue            |-  |DKP white 22 pin connector  |
|       LOCK MOTOR|blue/red            |   |drivers door harness        |
|     UNLOCK MOTOR|blue/white          |   |drivers kick panel *1       |
|    DISARM DEFEAT|blue                |   |passenger kick panel *2     |
| PARKING LIGHTS +|GREEN/ red           |   |drivers kick in a black plug|
| PARKING LIGHTS -|yellow or grn/yel   |   |steering column             |
|       HEADLIGHTS|red or RED / blue     |-  |steering column             |
|     DOOR TRIGGER|RED / green           |-  |drivers kick in a white plug|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|GREEN/ red           |-  |keyless module *3           |
|TRNK/HTCH RELEASE|lt. green           |   |keyless module *3           |
|  FCTRY ALARM ARM|purple *5           |-  |drivers kick in a white plug|
|FCTRY ALRM DISARM|yellow/blue *5      |-  |drivers kick in a white plug|
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ red           |   |dkp, blk 22 pin plug, pin 4 |
|      SPEED SENSE|blue/black          |   |dkp, blk 22 pin plug, pin 2 |
|       BRAKE WIRE|red                 |+  |brake switch                |
|     HORN TRIGGER|green               |-  |steering column             |
|           WIPERS|blu/yel & blu/wht   |+  |steering column             |
|  LF WINDOW UP/DN|brn/wht - brn/red   |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - brn/red   |A  |RF window switch            |
|  LR WINDOW UP/DN|brn/wht - brn/red   |A  |LR window switch            |
|  RR WINDOW UP/DN|brn/wht - brn/red   |A  |RR window switch            |
| SUN RF OPN/CLOSE|purple - blue       |A  |sunroof motor *4            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|RED / white           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / yellow          |+  |radio                       |
| RADIO ILLUMINATE|GREEN/ red           |+  |radio                       |
|       LF SPEAKER|blue - yellow       |   |radio or speaker            |
|       RF SPEAKER|green - gray        |   |radio or speaker            |
|       LR SPEAKER|orange - white      |   |radio or speaker            |
|       RR SPEAKER|orn/blu - orn/wht   |   |radio or speaker            |
Notes:
*1 In a white 10 pin connector  *2 Located up high in a white connector  *3 The keyless module is located to the right of the glove box.  *4 The sunroof motor is located in front of the sunroof in the headliner.  *5 Trigger the power lock and the factory alarm arm wires at the same time to arm the alarm.  Trigger the power unlock and the factory alarm disarm wires at the same time to disarm the alarm.
djerizix
Posted: April 29, 2003 at 12:15 PM / IP Logged
very fast reply, thanks again!
Posted: April 29, 2003 at 12:17 PM / IP Logged
No problemo
djerizix
Posted: April 29, 2003 at 1:25 PM / IP Logged
I'm sorry I forgot to mention that my car already has a factory anit theft system/keyless entry, I was wanting to just remove it from the car.
Or would it be best to just leave it in and bypass or addon to it. I really hate the horn honking everytime I unlock/lock the doors.
Posted: May 01, 2003 at 8:10 AM / IP Logged
So are you just installing a remote starter or is the unit a combo alar/remote starter ? If it's a combo unit you are installing then you should remove the old system by cutting the wires off the harness ( but make sure you leave about 3 " on the wire so you can splice the new system in ).
