2006 highlander hybrid starter disable
asetliff
Member - Posts: 7
Posted: September 18, 2012 at 9:07 PM / IP Logged
2006 Toyota Highlander Hybrid. I need to disable the starter. The wiring appears simple and the same as a gas version. Will cutting the starter wire stop the gas and electric motor function?
Posted: September 19, 2012 at 12:27 AM / IP Logged
Funnily enough I'm pursuing the same problem with the Prius.
It's simpler to chase the wire from the brake switch, either input or output, not blue that only feeds the brake lights.
Trouble is the damn thing is inaccessible on right hand drive versions and I'm awaiting dealership help to trace back one of the others to a more convenient point.
ropuma
Copper - Posts: 102
Posted: September 19, 2012 at 7:59 AM / IP Logged
If is not push button cut the black(starter) it will work fine
asetliff
Member - Posts: 7
Posted: September 25, 2012 at 7:43 AM / IP Logged
Correct.  Black wire was cut and the vehicle will not start.  If you crank the vehicle and then cut the start wire the hybrid function of the vehicle worked fine with the engine shutting down at stoplights and restarting when you apply the gas. For what I was doing this wasn't different than a gas version.
