2012 Toyota 4Runner Remote Start Wiring
chiarlanza
Member - Posts: 30
Posted: December 17, 2012 at 11:06 PM / IP Logged
Looking for 2012 Toyota 4Runner remote start wiring.
shortcircuit161
Silver - Posts: 556
Posted: December 18, 2012 at 8:09 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / 4RUNNER / 2012 / Remote Start
[PRINT THIS PAGE]
12volts      green (30A)      +      ignition switch, white 8 pin plug, pin 7
Notes: If equipped, the Satellite Radio Tuner is under the front passenger seat.
Starter      red      +      ignition switch, white 8 pin plug, pin 8
Second Starter      black      +      ignition switch, white 8 pin plug, pin 1
Ignition      black      +      ignition switch, white 8 pin plug, pin 6
Second Ignition      purple      +      ignition switch, white 8 pin plug, pin 4
Third Ignition      N/A
Accessory      red      +      ignition switch, white 8 pin plug, pin 3
Second Accessory      N/A
Keysense      black      -      Body ECU, white 30 pin plug, pin 17
Notes: The Body ECU is under the driver dash, attached to the right side of the dash fuse box.
Power Lock      black (passenger door switch)      -      Body ECU, white 30 pin plug, pin 9
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlock      white (passenger door switch)      -      Body ECU, white 30 pin plug, pin 10
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motor      blue      5 wire      dash fuse box, white 36 pin plug (2F), pin 8
Unlock Motor      white      5 wire      driver kick, white 20 pin plug, pin 1
Parking Lights+      green      +      dash fuse box, white 36 pin plug (2F), pin 16
Parking Lights-      red      -      Body ECU, white 30 pin plug, pin 30
Hazards      white      -      Body ECU, white 30 pin plug, pin 3
Turn Signal(L)      yellow (F), yellow (R)      +      turn signal flasher right of dash FB, white 18 pin plug, pins 10 and 2
Turn Signal(R)      lt. blue (F), lt. blue (R)      +      turn signal flasher right of dash FB, white 18 pin plug, pins 17 and 8
Reverse Light      red      +      dash fuse box, white 36 pin plug (2F), pin 4
Door Trigger      red      -      dash fuse box, white 36 pin plug (2F), pin 27
Dome Supervision      green      -      dash fuse box, rear, white 40 pin plug (2B), pin 18
Trunk/Hatch Pin      pink      -      Back Door ECU in liftgate, white 26 pin plug, pin 10
Hood Pin      black      -      dash fuse box, white 40 pin plug (2D), pin 23
Trunk/Hatch Release      use trunk release motor
Power Sliding Door      N/A
Factory Alarm Arm      lt. green (driver door key lock)      -      Body ECU, white 30 pin plug, pin 11
Factory Alarm Disarm      gray (driver door key unlock)      double -      Body ECU, white 30 pin plug, pin 24
Disarm No Unlock      use keysense
Tachometer      pink      ac      data link connector, white 16 pin plug, pin 9
Wait to start      N/A
Brake Wire      PURPLE / green to blue      +      brake switch or dash fuse box, white 36 pin plug (2F), pin 29
Parking Brake      lt. green      -      dash fuse box, white 40 pin plug (2D), pin 17
Horn Trigger      gray to gray/blue      -      horn switch or dash fuse box, white 40 pin plug (2D), pin 29
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Modules: Not Available
