2016 Scion iA Alarm/Remote Start Wiring
muttnsnuff
Posted: July 18, 2019 at 6:21 PM / IP Logged Link to Post Post Reply Quote muttnsnuff
Looking for installation wiring diagrams to install remote start and alarm. Thank you
wirewise
Moderator - Posts: 489
Posted: July 18, 2019 at 6:38 PM / IP Logged Link to Post Post Reply Quote wirewise
SCION IA
MODEL      YEAR(S
IA      2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2 INTERFACE FOR REMOTE STARTING
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      WHITE (+)      camshaft position sensor, 4 pin plug, pin 1 or 2
STARTER      GRAY (+)      Start Stop Unit in steering column, white 24 pin plug, pin 23
STARTER 2      N/A
IGNITION 1      YELLOW (+)      Start Stop Unit in steering column, white 24 pin plug, pin 10
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      PINK (+)      Start Stop Unit in steering column, white 24 pin plug, pin 2
ACCESSORY/HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      PINK (-) USE HAZARDS      Start Stop Unit in steering column, white 32 pin plug, pin 4
PARKING LIGHTS ( + )      N/A
POWER LOCK      PINK(-) THRU 1000 ohms (ONE WIRE SYSTEM)      BCM above driver kick, white 32 pin plug, pin 6
POWER UNLOCK      PINK (-)      BCM above driver kick, white 32 pin plug, pin 6
LOCK MOTOR WIRE      TAN (5-WIRE)      ESU in driver kick, white 8 pin plug, pin 2
DOOR TRIGGER      GREEN (-)      BCM above driver kick, white 32 pin plug, pin 20
DOMELIGHT SUPERVISION      RED (-)      ESU in driver kick, white 18 pin plug, pin 16
TRUNK RELEASE      GREEN (-)      BCM above driv kick, white 24 pin plug, pin 11
SLIDING POWER DOOR      N/A
HORN      PINK (-)      horn switch, white 14 pin plg, pin 1 or BCM, white 24 pin plug, pin 22
TACH      BROWN (AC)      camshaft position sensor, engine driver side, gray 3 pin plug, pin 1
WAIT TO START LIGHT      N/A
BRAKE      BLUE (+)      Start Stop Unit in steering column, white 32 pin plug, pin 2
FACTORY ALARM DISARM      BROWN (-)      BCM above driver kick, white 32 pin plug, pin 22
ANTI-THEFT      VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2 INTERFACE FOR REMOTE STARTING
~wirewise~
muttnsnuff
Posted: July 18, 2019 at 6:44 PM / IP Logged Link to Post Post Reply Quote muttnsnuff
Would a bd3 bypass work?
muttnsnuff
Posted: July 18, 2019 at 7:34 PM / IP Logged Link to Post Post Reply Quote muttnsnuff
Need some picture instructions for installing remote start/alarm
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
