2009 Honda Accord, Remote Start Wiring
mrvil72
Posted: January 17, 2021 at 7:00 PM / IP Logged Link to Post Post Reply Quote mrvil72
Does anyone have a tech sheet on where the parking light and the trunk release wire is on a 2009 Honda Accord 4dr? I tried following the ones this site but no luck. If you have pictures, that’ll be even better.
4Runner-4life
wirewise
Moderator - Posts: 489
Posted: January 17, 2021 at 7:55 PM / IP Logged Link to Post Post Reply Quote wirewise
ACCORD     2009-2012
KEY     T-HARNESS     IMMOBILIZER
N/A     N/A     HONDA'S TRANSPONDER SYSTEM, See NOTE #1
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     WHITE (+)     @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 2
STARTER     YELLOW (+)     @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 1
STARTER 2     N/A
IGNITION 1     BLUE (+)     @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 5
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     ORANGE (+)     @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 3
ACCESSORY/HEATER BLOWER 2     RED(+)     @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 4
KEYSENSE     N/A
PARKING LIGHTS ( - )     GRAY (-)     @ HEADLIGHT SWITCH, (BLACK/WHITE, 12-Pin Plug) Pin 11
PARKING LIGHTS ( + )     RED (+) (Left Front and Left Rear) Note #2     @ DRIVERS DASH FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 11
POWER LOCK     ORANGE (-) TYPE B, SEE NOTE #3     @ POWER WINDOW MASTER SWITCH,(GRAY, 37-Pin Plug) Pin 28
POWER UNLOCK     BROWN & WHITE (-) TYPE B, SEE NOTE #3 AND #4     @ POWER WINDOW MASTER SWITCH, (GRAY, 37-Pin Plug) Pins 29 and 31
LOCK MOTOR WIRE     ORANGE (5-wire type)     SEE NOTE #5
DOOR TRIGGER     BROWN (-)     @ DRIVERS DASH FUSE BOX, (LT.GREEN 16-Pin Plug) Pin 12
DOMELIGHT SUPERVISION     PINK (-)     Below DRIVERS DASH FUSE BOX, (WHITE, 4-Pin Plu) Pin 2 or WHITE 20-Pin Plug, Pin 12
TRUNK RELEASE     USE TRUNK RELEASE MOTOR WIRE
SLIDING POWER DOOR     N/A
HORN     ORANGE or GREEN/YELLOW (-)     @ HORN SWITCH or DRIVERS DASH FUSE BOX, (LT.GREEN 33-Pin Plug) Pin 23
TACH     ANY WIRE NOT YELLOW/BLACK (INLINE 4), YELLOW (V6) (AC)     @ Any FUEL-INJECTOR
WAIT TO START LIGHT     N/A
BRAKE     LT. GREEN (+)     @ BRAKE SWITCH or DRIVERS DASH FUSE BOX, (LT.GREEN 33-Pin Plug) Pin 2
FACTORY ALARM DISARM     SEE POWER UNLOCK
ANTI-THEFT     HONDA'S TRANSPONDER SYSTEM, Requires Bypass Module, See NOTE #1     @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: HONDA'S TRANSPONDER SYSTEM, Requires Bypass Module: (For Remote Starting Only) Part #791 Bypass, (Requires Extra Key) for Operation. (For Remote Starting Only) Part # PK-ALL Bypass. (No Extra Key Required for Operation) 2-KEYS Required to Program Module. (For Remote Starting/Door Locks) Part # DB-ALL (No Extra Key Required for Operation) 1-KEY Required for Programming.
NOTE #2: the RIGHT FRONT wire is GRAY (+) @ the PASSENGER KICK FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 11
NOTE #3: TEST these wires while turning the Key in the Drivers Door.
NOTE #4: the BROWN (-) is the DOOR Key Cylinder UNLOCK wire and WHITE(-) is the DOOR UNLOCK Detection wire. Use BOTH wires and Diode Isolate. Program module for Double Pulse Unlock
NOTE #5: on the 2-DOOR, this wire is located in the Drivers Kick Panel. On the 4-DOOR, this wire is located @ DRIVERS DASH FUSE BOX, (GREEN 16-Pin Plug) Pin 9
~wirewise~
mrvil72
Posted: January 21, 2021 at 2:39 PM / IP Logged Link to Post Post Reply Quote mrvil72
Thanks, I also forgot I had to reverse the polarity for the trunk release.
4Runner-4life
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
