1999 Chevrolet Tahoe, Remote Start Wiring
sparxx513
Copper - Posts: 56
Posted: September 06, 2022 at 5:34 AM / IP Logged Link to Post Post Reply Quote sparxx513
Can someone please upload a current tech sheet on this one? Ive found a few conflicting ones depending on where I look. Will be installing a Compustar RS/Alarm combo. Using a blade for the passlock bypass.
Platinum - Posts: 13,726
Posted: September 09, 2022 at 8:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      red (40A)      +      ignition harness      Directwire
Second 12 Volts      red (50A)      +      ignition harness      Directwire
Ground      (chassis ground)
Starter      yellow or violet      +      ignition harness      Directwire
Ignition      pink      +      ignition harness      Directwire
Second Ignition      white      +      ignition harness      Directwire      Notes
Accessory      orange      +      ignition harness      Directwire
Second Accessory      brown      +      ignition harness      Directwire
R Code      yellow      Passlock 2      Passlock sensor on ignition key cylinder      Directwire
Reference Ground      orange/black      -      Passlock sensor on ignition key cylinder
Keysense      lt. green      -      ignition harness      Directwire
J1850      violet      data      OBD-data link connector, black 16 pin plug, pin 2
Power Lock      lt. blue      + or reverse      driver kick --or-- door lock relay above gas pedal, black 6 pin plug, pin F      Directwire      Notes
Power Unlock      white      + or reverse      driver kick --or-- door lock relay above gas pedal, black 6 pin plug, pin A      Directwire      Notes
Lock Motor      gray      reverse      driver kick --or-- door lock relay above gas pedal, black 6 pin plug, pin E      Directwire
Driver Unlock Motor      tan      reverse      driver kick --or-- Keyless Module above gas pedal
Passenger Unlock Motor      tan      reverse      passenger kick --or-- door lock relay above gas pedal, black 6 pin plug, pin B      Directwire
Parking Lights      brown      +      headlight switch      Directwire
Headlight      yellow      +      headlight switch
Left Front Door Trigger      violet      -      headlight switch      Directwire
Right Front Door Trigger      same as left front door trigger
Left Rear Door Trigger      same as left front door trigger
Right Rear Door Trigger      same as left front door trigger
Dome Light      gray      -      headlight switch
Trunk/Hatch Pin      same as left front door trigger
Trunk/Hatch Release      black or black/white or tan      + or reverse      low in the drivers kick           Notes
Tachometer      white      ac      ECM on driver fender, black plug marked white      Directwire
Wait to Start      dk. blue (need to diode isolate see Tech Doc 1090)      -      instrument cluster
Clutch Pedal      violet/white      +      clutch switch
Rear Defroster      violet      +      driver dash relay block
Mirror Defroster      same as rear defroster
Speed Sense      dk. green/white      ac      radio
Brake Wire      white      +      brake switch or steering column      Directwire
Parking Brake      lt. blue      -      parking brake switch
Horn Trigger      black      -      steering column      Directwire
Wipers      violet      +      steering column
Left Front Window (Up/Down)      dk. blue - brown      A      drivers door switch
Right Front Window (Up/Down)      lt. blue - tan      A      drivers kick panel
Left Rear Window (Up/Down)      dk. green - violet      A      drivers kick panel
Right Rear Window (Up/Down)      lt. green - violet      A      drivers kick panel
