2007 Chrysler 300, Window Wiring
jsnali13
Member - Posts: 40
Posted: December 09, 2022 at 2:15 PM / IP Logged Link to Post Post Reply Quote jsnali13
Hi everyone,
Im looking to put in DEI 535t for the windows in a 2007 chrysler 300.
Would anyone know what the wires are for the 4 windows and where they are?
Most of the wires are on the passenger side of the vehicle, but there is a bunch on the driverside. Im guessing the wires should be there since the driverside does controll 4 windows.
mgoetz74
Silver - Posts: 424
Posted: December 10, 2022 at 9:20 AM / IP Logged Link to Post Post Reply Quote mgoetz74
Left Front Window (Up/Down)     orange/white - orange/lt. green (base models)     A     power window main switch, lt. gray 8 pin plug, pins 6 and 7
Right Front Window (Up/Down)     orange/gray - orange/tan (base models)     A     driver kick, door harness
Left Rear Window (Up/Down)     orange/gray - orange/white     A     driver kick, door harness
Right Rear Window (Up/Down)     orange/dk. blue - orange/lt. blue     A     driver kick, door harness
jsnali13
Member - Posts: 40
Posted: December 22, 2022 at 11:26 PM / IP Logged Link to Post Post Reply Quote jsnali13
Thank you!
jsnali13
Member - Posts: 40
Posted: February 21, 2023 at 10:45 PM / IP Logged Link to Post Post Reply Quote jsnali13
So im lost. I cant finds a orange/light green in the grey plug.
Grey plug has 7 wires, front windows has 5 wires and is a black plug.
I can control both front windows with the grey unplugged.
I did find a schematic and the wires you provided are correct.. did it change for the touring?
I have a 2007 300 touring base model. So no sound system. Regular chip key. Not sure if any of that helps or matters.
Will try to post pics of the wires
jsnali13
Member - Posts: 40
Posted: February 21, 2023 at 10:53 PM / IP Logged Link to Post Post Reply Quote jsnali13
2007 Chrysler 300, Window Wiring -- posted image.
First is the grey plug wires.
2nd is the black plug wires.
jsnali13
Member - Posts: 40
Posted: April 09, 2023 at 1:26 PM / IP Logged Link to Post Post Reply Quote jsnali13
I found this from a 300 forum:
The front windows are Canbus controlled. You can bypass that for the window modules by wiring directly to the motor inputs in the door.
The rears are not Canbus controlled, so you can wire them up under the dash
I followed it..I may have to chage the switch wires to directly to the switches and not the control module. Windows go up when i arm the car, but doesnt work with aux inputs. Plus i cant seem to program the modules. When i ground the red/white wire from the module for programming the windows move down slightly then down all the way. Its says hold the driverside switcb up for a few seconds and the windows should move.. they dont move for me.
The rear windows are wired in the kick panel as per above by Blowndakrt. But seems the switches in each door stopped working. I can only use the windows from the master switch.
Any ideas? Do i need to wire earch rear door as well?
jsnali13
Member - Posts: 40
Posted: April 17, 2023 at 4:16 PM / IP Logged Link to Post Post Reply Quote jsnali13
Is there anyway to bypass the master switch front auto up?
Ive wired the 535 direct to the motors in the door.
They need to show constant power when i hold the button up to get into programming mode.
When i hold the switch, power to the motor is only 1 second both up and down.
I tried to cut the switch wire at the 5 pin harness under the switch and hook that up directly to the 535 switch input.. but does nothing.
I beleive it was the tan/orange that when gounded puts the window up. I tried to just ground the wire to put the 535 in programming mode as it showed constant power.. but that also didnt work.
Not sure how to bypass the auto up/down
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
