2016 Nissan Titan, Diesel, Push To Start, Alarm/Remote Start Wiring
goodzman
Posted: May 16, 2024 at 7:44 PM / IP Logged Link to Post Post Reply Quote goodzman
I'm looking for the alarm/remote start wiring information on a 2016 Nissan Titan XD diesel with push button start. Can anyone help me out?
Platinum - Posts: 7,828
Posted: May 17, 2024 at 8:07 AM / IP Logged Link to Post Post Reply Quote kreg357
Being as the truck has an ignition immobilized system, I'm assuming that you will use a bypass module to allow a R/S. There are complete systems available from Fortin, Compustar and iDataStart that can handle your truck. They even have T-Harness's for those systems to make the install easier.
Below is a link to a system from Fortin not using a T-Harness that shows the vehicles wires :
https://fortin.ca/download/66401/EVO-ONE_IG_REG_BI_NIS_TITAN_2016_PTS_B_66401.pdf
And here is the same system using a T-Harness:
https://fortin.ca/download/75771/EVO-ONE_IG_THR_BI_NIS4_TITAN_2016_PTS_B_75771.pdf
These systems control the locks and alarm via the CAN bus. They also supply a Tach signal, the foot Brake signal and door and hood status.
The downside is that these systems need to be flashed with the correct firmware for your exact installation prior to use. You can do this yourself with additional equipment ( Flashlink 2 ) or you could find an online seller that would perform this firmware flash prior to shipment.
goodzman
Posted: May 17, 2024 at 9:50 AM / IP Logged Link to Post Post Reply Quote goodzman
I am using idatalink and compustar remote equipment. I have everything I need to program and install. Looking for the wiring for the truck.
Posted: May 17, 2024 at 1:47 PM / IP Logged Link to Post Post Reply Quote kreg357
Typically all the standard wiring is included with the install guide. Compustar example below :L
https://images.idatalink.com/vehicle-install-guides/Guides/504/341/22382/EN/RSA-NI3-[CMHCXA0]-(Nissan_Titan_2016_22382)-EN-D_20240229_212413.pdf
goodzman
Posted: May 17, 2024 at 10:20 PM / IP Logged Link to Post Post Reply Quote goodzman
It doesn't show the power wire. I see that the first pages you sent do. Thanks
