2002 Windstar door trigger
ihookitup4u
Member - Posts: 23
Posted: June 28, 2003 at 12:35 AM / IP Logged
I have the omega research and I have tryed Dei's direct fax , i still get a false every half hour. I do not know why. I have tryed the diode in the rear passenger tail light area and i have found 2 of the same colors and tryed them both. What do I do. Please help. I will help you all now that i know of this site, mustangs w/same problem i can fix, why not this windstar????
Platinum - Posts: 12,488
Posted: June 28, 2003 at 8:17 AM / IP Logged
A diode must be placed in-line on this wire to avoid falsing problems. Cut the wire and put the cathode side away from the dome light, then tie the door trigger input on the cathode side on the BROWN / pink. On models with the puddle lamps on the doors, can also use ORANGE / white in a 20 pin plug at the FEM for door trigger. DO NOT USE THE ORANGE / WHITE FOR DOME LIGHT SUPERVISION.
You may also need to relay isolate this wire as well as diode isolate it.Email me for the relay diagram if you wish.
