2002 dodge ram alarm/remote start
honch057
Posted: December 17, 2003 at 8:20 PM / IP Logged
When i leave my key in the ignition and exit the truck the alarm does not recognize this and auto locks. is there a way to allow the alarm to recognize the key is in ingition?
also.  What is the wire for the tach sense function? the only info i can find is what wire it is NOT.   i need which wire and location that it IS.
thanks
Geeque
Silver - Posts: 310
Posted: December 24, 2003 at 10:45 AM / IP Logged
Here this will help:
1500 DODGE RAM 2002 2DR PICKUP   SecurityBattery   RED +   (+)   IGNITION SWITCH HARNESSIgnition   DRK. BLU   (+)   IGNITION SWITCH HARNESSStarter01   YEL +   (+)   IGNITION SWITCH HARNESSAllDoorTrigger   BRN   (-)   DRIVERS B PILLARFrontLeftDoorTrigger   TAN   -   DRIVERS KISKFrontRightDoorTrigger   TAN/RED   -   DRIVERS KICKRearLeftDoorTrigger   N/ARearRightDoorTrigger   N/ATrunkTrigger   N/AHoodTrigger   N/AFactoryAlarmDisarm   LT.GRN/ORG(-)   DR. KICK GROUND PULSE THROUGH  OHMFactoryAlarmArm   LT.GRN/ORG(-)   DR. KICK GROUND PULSE THROUGH 760 OHMParkingLights   VIO/YEL -   (-)   RELAY ISOLATE GROUND W/320 OHM RESISTORLowCurrentParkingLights   85 TO GND 86 TO POS. OF ALARM 87A TO SW.SecurityParking LightsUSE A 320 OHM RESISTORRemote StartBattery   RED +   (+)   IGNITION SWITCH HARNESSIgnition   DRK. BLU   (+)   IGNITION SWITCH HARNESSIgnition02   RED +   (+)   IGNITION SWITCH HARNESSIgnition03   RED / WHT +   IGNITION SWITCH HARNESSAccessory01   BLK/WHT +   (+)   IGNITION SWITCH HARNESSAccessory02   BLK/ORG   +   IGNITION SWITCH HARNESS Starter01   YEL +   (+)   IGNITION SWITCH HARNESSAntiTheftSystem   NONEKeySense   BLU  (-)   IGNITION SWITCH HARNESSNeutralSafety   BLK/WHT   (-)   IGNITION SWITCH HARNESSTach   RED / BLK   OR   (AC)   BLK/GRY AT COIL ON DRV.SIDE OF ENGINECrankShaftSensor   N/ACamShaftSensor   N/ASpeedSense   WHT/ORG   CONNECTOR C-2 PIN 27 AT PCMParkingLights   VIO/YEL -   (-)   RELAY ISOLATE GROUND W/320 OHM RESISTORLowCurrentParkingLights   85 TO GND 86 TO POS. OF ALARM 87A TO SW.BrakeLights   WHT/TAN +   (+)   AT BRAKE SWITCHReverseLights   VIO/BLK   (+)   (+)   16 PIN GRY CONN DRIVERS DASHHorn   BLK/RED   (-)   74 PIN CONN BEHIND DR. DASH OR COLUMN      PICKUP   Doorlocks / WindowPowerUnLock   WHITE/ GREEN -   (-)   DR. KICK PANEL USE 320 OHM RESISTORPowerLock   WHITE/ GREEN -   (-)   DR. KICK USE 680 OR 815 OHM RESISTORDriverDoorMotor01   PNK/BLK +   LEFT KICK PANELDriverDoorMotor02   ORG/BLK +   LEFT KICK PANELPassengerDoorMotor01   PNK/VIO +   LEFT KICK PANELLeftFrontWindow01   LF:LT.BLURightFrontWindow01   RF:BRN/WHTLeftRearWindow01   LF:WHTRightRearWindow01   RF:VIO/WHTSunRoofMotor01   N/ASunRoofMotor02   N/ADoorlocks / WindowsPower UnLockUSE 330 OHM RESISTORPowerLockUSE 820 OHM RESISTORConvenienceHeadLights   PURPLE / YELLOW   (-)   680 OHM RESISTOR,SAME AS PARK LIGHTSFrontLeftParkLightBulb   SIDE OF PPL/YEL 30 TO BCM SIDE OFFrontRightParkLightBulb   PPL/YEL 87 TO ONE SIDE OF RESISTOR THERearLeftParkLightBulb   OTHER SIDE TO GROUND. ALSO BLK/YEL(+)RearRightParkLightBulb   UNDER HOOD IN LARGE HARNESS BETWEEN DRV.HazardFrontLeft   FENDER AND FIREWALL.HazardFrontRight   N/AHazardRearLeft   N/AHazardRearRight   N/ALowSpeedWipers   BRN/WHT   AT SWITCH HARNESSTrunkRelease   N/AMobile Audio / VideoBattery   RED +   (+)   IGNITION SWITCH HARNESSAccessory01   BLK/WHT +   (+)   IGNITION SWITCH HARNESSGround   -Dimmer   ORG/WHT   (-)   RADIO HARNESSPowerAntenna   YEL   (+)   RADIO HARNESSFrontLeftSpeakerPos   DK.GRNFrontLeftSpeakerNeg   BRN/REDFrontRightSpeakerPos   VIOFrontRightSpeakerNeg   DARK BLUE/REDRearLeftSpeakerPos   BRN/YELRearLeftSpeakerNeg   BRN/LT.BLURearRightSpeakerPos   DK.BLU/WHTRearRightSpeakerNeg   DK.BLU/ORGAmp   BEHIND GLOVEBOX   PICKUP   Control ModulesRIGHT OF STEERING COLUMN
Gary Kline
MECP Master Technician
whcollier
Member - Posts: 21
Posted: January 30, 2004 at 1:52 PM / IP Logged
is there any difference in this wiring information between the 02 Ram 1500 2 door and the 02 Ram 1500 4 door trucks? I have a 4 door extra cab 4X4 and I am getting ready to start installing the audio/video/navigation stuff as well as a full alarm system with remote start and window roll up/down and radar sensor in the truck I just bought, it is a 2002 Dodge Ram 1500 4 Door Extended Cab 4X4 Automatic Trans 4 wheel Disc Brakes rear ABS and the cooles thing is it only had 6700 miles yup 6700 not 67000 miles and she looks brand spankin new... but she needs all the goodies like we have in our 97 Ram 1500 truck
Thanks in advance for any help
