2001 ford explorer
peds48
Posted: March 11, 2004 at 11:04 PM / IP Logged
i am looking for the wire diagram for the 2001 ford explorer any help appreciated.  i am installing a remote start as well along with a window relay and everithing else. thank you
boomer_106
Silver - Posts: 710
Posted: March 15, 2004 at 11:11 AM / IP Logged
Ford
Explorer
1997-2001
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED / L BLUE
IGNITION SWITCH HARNESS **
Ignition #1:
L GREEN/ PURPLE
Ignition #2:
GRAY / YELLOW
IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3:
2ND GRAY / YELLOW
IGN. SW. HARN. (BLOWER & AIRBAG)
Accessory:
BLACK/ L GREEN
Brake Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
TAN / YELLOW
PIN ## AT POWERTRAIN CONTROL MOD. *
Parking Lights:
WHITE/ BLACK (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
D GREEN/ PURPLE (-)
DRIVER KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Powertrain Control Module Located On Passenger Rear Corner Of Engine Compartment. ** 1998 Vehicles May Be Equipped With Ford's PATS Anti-Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems.
Ford
Explorer
1997-2001
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
YELLOW (2)
Starter Kill:
RED / L BLUE
Ignition +12 Volts:
L GREEN/ PURPLE
Dome Lights/Superv:
BLACK/ L BLUE (+)
AT COURTESY LIGHT ****
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power Lock:
PINK / YELLOW
DRIVER KICK PANEL *****
Power Unlock:
PINK/L GREEN
Trunk Release:
N/A
Alarm Input Wire:
BLACK/ L BLUE (+)
Notes:
*** BLACK/ L BLUE (+) Wire Also Located At Interior Lamp Switch. **** See Note #201- Negative Pulse Door Lock Diagram.
