03 Gulfstream Atrium Motorhome VSS
tom small
Member - Posts: 36
Posted: April 28, 2004 at 6:18 PM / IP Logged
need vss on 03 gulfstream atrium motorhome.  has a 330 diesel caterpillar engine and a class A freightliner frame.  local RV dealers are unwilling to crack open their magic tech books.  please help!
auex
Platinum - Posts: 5,041
Posted: April 28, 2004 at 6:29 PM / IP Logged
I can't find any info on any gulfstream, I think you are on your own for this one. I would recommend that you pull the inst cluster and start there.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mark mcj
Member - Posts: 19
Posted: May 19, 2004 at 10:03 PM / IP Logged
Look for a sensor off the tailend of the tranny. Hopefuly the sensor will have only 2 wires, one will show gound and the other will vary with movement of the rear whells.
You may need to get a magnet kit, but there should be a VSS wire under there somewhere.
mark mcj
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
