96 cavalier door locks
iceman88
Member - Posts: 11
Posted: October 17, 2004 at 3:09 AM / IP Logged
how do i go about connecting the door lock wires from an aftermarket alarm to a 96 chevy cavalier (not keyless entry model)?
boomer_106
Silver - Posts: 710
Posted: October 17, 2004 at 9:42 AM / IP Logged
Here ya go. Make sure you read the bottom.
Chevrolet
Cavalier
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
ORANGE
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
D BLUE (LO)
(-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEMATICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE At PCM. ** This vehicle is equipped with GM's PASSLOCK Anti-Theft system. See Note #113 - General Motors PASSLOCK Bypass Diagram.
Chevrolet
Cavalier
1996-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
L GRN/BLK & L BLUE (-)
AT CONVENIENCE CENTER MODULE ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
L BLUE
PASSENGER KICK PANEL
Power  Unlock:
WHITE
MUST TEST WITH PASSENGER SWITCH****
Trunk  Release:
BLACK/ WHITE (+)
AT OEM KEYLESS MODULE
Alarm  Input Wire:
Notes:
*** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. Alternatively, connect the alarm input to the domelight in the roof. **** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram.
