04 dodge ram: need good accessory wire
Hoot
Member - Posts: 10
Posted: February 15, 2005 at 7:05 PM / IP Logged
i'm looking for a good wire to get accessory position power on an 04 dodge ram 1500 hemi. preferably hot while cranking and it needs to be able to handle enough current to close a 200amp solenoid that i'm using as a relay. not sure on the exact current draw of that solenoid's coil, hopefully somebody here is familiar with it. here's a pic of what i'm talking about...
04 dodge ram:  need good accessory wire -- posted image.
Hoot
Member - Posts: 10
Posted: February 15, 2005 at 7:19 PM / IP Logged
ooops. screwed up the pic. try this...
Hoot
Member - Posts: 10
Posted: February 15, 2005 at 7:21 PM / IP Logged
ok, screw the upload. here's the URL.
http://home.comcast.net/%7Eeverswa/inside_console.JPG
twgps
Member - Posts: 9
Posted: February 23, 2005 at 1:46 AM / IP Logged
Grab a multimeter and check the dark blue wire in the ignition switch harness.
The GPS Guy
